This is a continuation from my original post found here.
http://www.kawasakimotorcycle.org/fo...arts-sale.html
I just realized that I have been posting in the wrong category...sorry.
I have recently gone through the garage and have found other items that were in boxes that I was unaware of. Here is the revised list.
Thank You.
91 KAWASAKI ZX-11
Coils $35 (pair)
Black Box $50
Wiring Harness $40
Regulator/Rectifier $35
Fuel Pump $40
Radiator $75
Radiator fan $15
Front Rim / Wheel $100 (maroon (Rose) polished edges MINT)
Driver Brake Peg Assembly $30 (peg,bracket,lever,link)
Left & Right Passenger Peg Assembly $15 (each)
Front Rotors $75 (pair)
Rear Rotor $35
Rear Aluminum 48 Tooth Sprocket $25 *SOLD*
3 PC Rotor Set $100
Speedometer Guage Assembly $65 (13,987 miles)
Master Cyl. 35 (each w/ lever...clutch or brake)
Shock $40 (w/ links & dogbones) (nitrogen filled)
Tail light $20
Lock Set $75 (ign., tank, cargo)
Forks and Triple clamps $150
Front Brake Calipers $55 (pair)
Grab rail $15 (polished)
Aftermarket Exhuast $95 (V&H)
Left & Right Switches $15 (each) (start/run, headlight)
Guage & Fairing bracket $35
Clipons $15 (each...bar,clamp,bar ends)
Rear Caliper & Master Cyl. $40 (w/ Brace and fluid resevoir)
Rear Axle $10 (w/ Left & Right Adjusters)
Thermostat Assembly $5
Front Axle $10 (w/ spacer & collars)
Front Axle Speedometer Drive Assembly $10 (w/ Cable)
Right Mirror $20
Rear Seat Bracket $5 (w/ Helmet Strap Hooks)
Rear Seat Bracket $5 (bolts to rear Grab Rails)
Front Seat Bracket $5
Kickstand $10 (w/ Switch)
Rear Rim/Wheel Hub $15 (w/ cush drive rubbers)
LinkBack URL
About LinkBacks
