matching piston sizes used on different machines - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 03-05-2017, 07:16 AM Thread Starter
79 ke250
Hi everyone I'M a new member and this is my first post. I have a 79 KE 250 and I have discovered that the piston and rings have been discontinued for many years. I was lucky enough to track down a NOS set of rings for the Ole girl. A piston however seems to be next to impossible. So in research I have discovered that the 84 CR250 Has a piston that is identical 66mm bore 18 mm pin but it is a 246 cc instead of a 249cc displacement like the ke .Meaning the stroke is .75mm less on the cr. won't quite make it to TDC on the ke. Does anyone have any experience using a different piston in an engine other than one made specifically for that engine? is .75mm going to affect the compression ratio a great deal? has anyone used sealant for a base gasket instead of an actual gasket? I'm thinking if I did that I could minimize the stroke difference
thanks in advance!
jfougere123 is offline
Sponsored Links
Advertisement
post #2 of 2 (permalink) Old 03-05-2017, 11:37 AM
Senior Member
There are many more considerations than just bore and pin diameters. A few include:
1. Pin location.
2. Skirt length.
3. Ring width and numbers.
4. Ring location.
5. Dome shape/location.
6. The stroke on your machine has not changed, so that does not count.
What is wrong with your old piston?
sfair is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
