Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Adventure Biking / Dual Sport
Old 06-10-2008   #1 (permalink)
renzy1
Default kmx125 converted to 200
hi,ive changed the complete top end kmx125 to a 200 ie head,piston,powervalve ive also changed the exhaust for a complete big1 kmx200 and im using the 200 carb and airbox which is the same size as the 125.
the problem is the bike does'nt have any top end power,it goes flat at 7000 rpm but will rev to 10,000 but with no guts!im still running the bike with the 125 cdi instead of the 200 would this be a problem??
any help would be great thanks..
renzy1 is offline   Reply With Quote
Old 06-30-2008   #2 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
Hi, whats the jetting like on it? With mine I had to put the jets from the 125 carb and I did get a 200 cdi and a 200 exhaust because as you said it kept falling flat at 7000rpm and losing all power from there, it improved slightly (9000rpm and drop dead) then I did the jetting on it and it would rev to 10000 rpm with some encouragement.
I arn't very impressed with it to be honest because I just can't get it to keep up with my KX125 in a straight line and at the time I raced them my KX had about 120PSI of compression and the KMX had 175PSI so the KMX should have eaten it alive.
Jamie
Bought 1996 CR250 but need to pick up.
Now after another Mad Kaw 125 to tear the garden up!
KickassKX125 is offline   Reply With Quote
200 rear tire w/ front pulley Trashman900C Kawasaki Cruisers 8 05-14-2008 10:31 PM
200 mm converted into inches ??????????? fastbandit Kawasaki Cruisers 10 05-05-2008 01:58 PM
KDX 200 Engine in a KX 125 Frame knickk Kawasaki Motocross and Offroad 7 08-26-2007 05:42 AM
89 KDX 200 I'm looking for replacement carb info. MXHowes Kawasaki Motocross and Offroad 1 08-24-2007 10:44 AM
Klx 300 Or Kdx 200 ? FD LT Kawasaki Motocross and Offroad 3 12-04-2005 09:02 PM
