Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Adventure Biking / Dual Sport
Old 07-01-2008   #1 (permalink)
mikesweat73
Default 1987 KLR 650 Electrical Issues
So I am driving to work yesterday and lose all power at about 55mph. No power at all for about 5 minutes. Then it miraculously starts back up and I am on my merry way. Get on the Eway does it again. wait about 10 minutes starts back up with a lot of cranking. Turn around get off the Eway stops for good this time no power even after I got out of work. Go out this morning undo the battery hook it back up. Starts ok, ride it for about 10 hard minutes. Does the same thing twice. I am thinking it's the voltage regulator, but I am no mechanic. PLEASE HELP. can I test the voltage regulator? could it be the ignition switch? what else might be overheating? Any help would be greatly appreciated.
Thanks,
Mike
mikesweat73 is offline   Reply With Quote
Old 07-01-2008   #2 (permalink)
Inquisitive
Inquisitive
mikesweat73, do you have a shop manual for your bike? Can make tracing electrical circuitry, especially for those not as familiar a much easier job. It is also possible you have only a wire in your system that is damaged / worn, and once hot is no longer making continuity. The same problem can occur at most any electrical connection / terminal point. Electrical "issues" that are intermittent, especially heat induced / related can be especially challenging. Have you changed your spark plug, sometimes something so simple can be the answer. Best of luck to you!
Inquisitive is offline   Reply With Quote
Old 07-01-2008   #3 (permalink)
mikesweat73
I am waiting, I ordered one and it should be here in 2 days or so. I've only had the bike for about 1 week. I will try my best to go through the wiring. Thanks alot!
Old 07-08-2008   #4 (permalink)
mikesweat73
Got to wiggling some wires and what not. Turns out it was just a bunch of nasty corrosion in the fuse box, cleaned her up and she is running great, thanks
1987 KLR 650 Electrical issues mikesweat73 The Mechanics Corner 5 07-09-2008 12:30 AM
'08 KLR vs. '08 Versys PlayboyPenguin Main Lobby 4 06-05-2008 06:51 PM
WTB: Oil Pressure Switch & Fuel Level Switch for 81 KZ-750 Little B Streetbikes Buy/Sell/Trade 0 12-11-2007 12:10 PM
Do the KLR 650 RADIATOR and PUMP Guard really work?? Turbo Boss Kawasaki Motocross and Offroad 1 12-24-2005 05:41 PM
