Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Adventure Biking / Dual Sport
Old 09-24-2008   #1 (permalink)
db4570
Default 2 more KE100 maintenance quesitons
OK- so I'm committed to this 1998 KE100 I bought. Problem is, I don't have a manual, so don't know the basic maintenance stuff. For example:
It appears it just uses regular 10W40 in the transmission, but how high do I fill it?
I know how to adjust the chain tension, but how do I square it up, or make sure it's parallel to the sprockets? It's tough to eyeball due to the swingarm configuration. What do you guys clean and lube your chains with? When I was a kid, we'd just slosh 'em around in a coffee can with gas, and glob some sort of motor oil on them. Any tecnological improvements since then?
OK- I know I said 2 questions, but hear's another: the rear end seems really sloppy. I know it's not some hot, tight cafe bike, but on the road it feels like the rear end is wobbling and wiggling on even mild turns. Is this just the way these things are, or can they be snugged up?
Thanks, guys!
David
db4570 is offline   Reply With Quote
Old 09-26-2008   #2 (permalink)
serlant
Who am i?
Send a message via MSN to serlant
For the oil, remove the oil level screw, situated next to the kickstart, and fill until it trickles out of the hole, then its full, as for the alignment, i believe there are notches on the swimgarm, they've just above the axle bolt. gimme a sec i'll try and get some pictures
The manual is only goes up to 87, but its bsically the same and i use it on my 1996 KH125
serlant is offline   Reply With Quote
Old 09-27-2008   #3 (permalink)
stevend135
Can't find time to ride
stevend135's Avatar
He pretty much summed it up
2000 Kawasaki Ke100 (seized engine)
1994 Suzuki Katana 750(sold)
2002 suzuki sv650 naked
stevend135 is offline   Reply With Quote
Old 10-04-2008   #4 (permalink)
db4570
Thanks for the pictures! I had looked for those marks, having vaguely remembered them from younger motorcycle days, but didn't find them. It turns out they were just covered in grime. Easier than I thought!
David
Old 10-13-2008   #5 (permalink)
Eflaher
DB4570- I just bought a 2001 Ke100 and the same thing happened, the rear end was all over the place. All the spokes were loose. Just get a spoke wrench and start checking them the loose ones won't have the same pitch when you give them a tap. If many of them are loose you may have to be a little more systematic on how you tighten them because you could warp the rim a little. Just go on YouTube and search for how to tighten dirtbike spokes.
Eflaher is offline   Reply With Quote
Old 4 Weeks Ago   #6 (permalink)
db4570
The spokes were really loose, and a couple were broken, which I bought replacements for but haven't yet replaced. I tightened the rest sort of by feel, but will try to figure out the official method.
Thanks for the input!
David
Old 4 Weeks Ago   #7 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
Another place where a Harley manual comes in handy as all shop manuals have wheel building instructions.
1982 Kawasaki KZ1000R1 #658
1979 Honda CB750/1123FZ
www.myspace.com/79cb750f
VN900LT Maintenance Spreadsheet Metal Thunder Kawasaki Cruisers 8 06-08-2008 08:38 AM
Maintenance contract on a vulcan 900 classic? Ronnie6657 Kawasaki Cruisers 12 05-16-2008 02:29 PM
600 mile break-in maintenance check Spok Kawasaki Cruisers 28 08-22-2007 11:31 AM
Mean Streak 500 mile maintenance help uf-engineer Kawasaki Cruisers 7 10-17-2005 02:47 PM
Future 1500 maintenance? T-man Kawasaki Cruisers 16 12-31-2004 12:23 PM
