Finally Got Into First Gear
Thanks for reading...
I have a 84 ZN 700 A1 (LTD) Its shaft drive, disc brake, 16 inch rear wheel. I want to replace the rear wheel with one that matches the front in the pic below (its from a 86 454 LTD (EN 450)) I know a 87+ Vulcan 750 has the same wheel, but drum brake...15 inch...but is the drive side the same? Or do these 2 bikes, LTD 700 and the Vulcan, use the same differential unit? I also know a 82 Spectre has same wheel I want, shaft drive, disc brake, 16 inch...but I want a 15 inch. I dont mind switching over to drum brake at all, as long as the drive side is the same. So basically...which vulcan years are the same diff unit as my 700? if any... and what year Spectre is the same drive as my 700 AND will the Spectre wheel be a direct bolt in swap? Thanks again.... |
Super Moderator
![]() Join Date: May 2006
The final gear case fits the following models,
ZL600-A1 1986 ZN700-A1 1984 ZN700-A2 1985 Is this what you were asking for?
25% discount on all O.E.M. Kawasaki accessories through 11/30/2009! |
Thanks Jake, I appreciate your response.
That gives me some direction...I guess the real answer Im after is what model wheel will actually mate to that diff. How about this picture...what models share this part? 42034 Perhaps a 86-96 Vulcan 750? Or maybe a 82-83 Spectre 750/1100? ![]() Thanks again, Jake Peace |
#4 (permalink) |
This may shed more light on where Im heading...all these list the drive hub as part 42034, but is it really the same part? Will all these drive hubs mate to my diff unit? Thanks again!
85 Vulcan 700 ![]() 93 Vulcan 750 ![]() 83 KZ750 Shaft ![]() |
#5 (permalink) |
Super Moderator
The part you are looking at is a part # 42034-1029, and fits the following models,
Model (34): KZ550-F1 (Spectre) (1983) KZ550-F2 (LTD Shaft) (1984) KZ550-M1 (LTD Shaft) (1983) KZ750-F1 (LTD Shaft) (1983) KZ750-N1 (Spectre) (1982) KZ750-N2 (Spectre) (1983) VN700-A1 (LTD) (1985) VN750-A10 (Vulcan 750) (1994) VN750-A11 (Vulcan 750) (1995) VN750-A12 (Vulcan 750) (1996) VN750-A13 (Vulcan 750) (1997) VN750-A14 (Vulcan 750) (1998 ) VN750-A15 (Vulcan 750) (1999) VN750-A16 (Vulcan 750) (2000 ) VN750-A17 (Vulcan 750) (2001) VN750-A18 (Vulcan 750) (2002) VN750-A19 (Vulcan 750) (2003) VN750-A2 (Vulcan 750) (1986) VN750-A20 (Vulcan 750) (2004) VN750-A21 (Vulcan 750) (2005) VN750-A3 (Vulcan 750) (1987) VN750-A4 (Vulcan 750) (1988 ) VN750-A5 (Vulcan 750) (1989) VN750-A6 (Vulcan 750) (1990 ) VN750A6F (Vulcan 750) (2006) VN750-A7 (Vulcan 750) (1991) VN750-A8 (Vulcan 750) (1992) VN750-A9 (Vulcan 750) (1993) ZL600-A1 (ZL600 Eliminator) (1986) ZL600-A2 (ZL600 Eliminator) (1987) ZL600-B2 (Eliminator 600) (1996) ZL600-B3 (Eliminator 600) (1997) ZN700-A1 (LTD Shaft) (1984) ZN700-A2 (LTD Shaft) (1985)
#6 (permalink) |
Thats awesome Jake, thank you. That leads me to believe that any wheel from those bikes will mate to my diff unit...
Now I have the option of a 16 inch direct swap in with disc..or a 15 inch which will give me a drum brake, which I must change over. But that drive side was what I really needed to know before buying any wheel online...the brake side I can deal with. Thanks again... |
| 79 kz1000 parts interchange | crashcourse101 | Vintage Motorcyle Info | 15 | 12-18-2008 01:49 PM |
| Buying new bike 1981 KZ1000 | rkj | Off Topic | 3 | 12-07-2008 03:32 PM |
| 1981 AR80 parts interchange | kikolemus | Vintage Motorcyle Info | 3 | 11-22-2008 11:54 AM |
| narrowing the search for parts | destarr | Accessory Swap Meet | 8 | 11-26-2007 10:25 AM |
| aftermarket parts for 2004 ninja 500R? | chimera | Kawasaki Streetbikes/Sportbikes | 2 | 08-13-2005 12:04 AM |
