Old 05-12-2009   #1 (permalink)
richiebanta1
Default no 4wd on brute force 750
i have a 2005 brute force 750,bought it with wiring issues and found out it was the bus bar,i fixed that problem and reset belt light and now it runs like crazy,but at first when you switched to four wheel drive the display stayed on 2 wheel and it was not engaging,check both actuators and theyre working fine,traced wiring to the controller and checked controller power per the manual and im only getting about 3 to 4 volts to the controller,could this still be from the bus connector?i have checked the underside of the fuse box and cleaned the connections and its still giving me the quick flashing code.any help would be appreciated
richiebanta1 is offline   Reply With Quote
Old 05-12-2009   #2 (permalink)
RCW
Way Too Much Free Time
Do the reset procedure for engine service and the controller voltage should come back to specified levels.
These have a safety feature that sets the service light, normally keeps the four wheel drive locked out, and limits the engine rpm if they are not serviced by a dealer for the initial valve adjustment. The same condition will occur if the belt or clutches are not operating per specification.
So, if you reset the light and it turns on again, I would be checking the torque converter tolerances and belt dimensions.
If you bypassed the ECM control circuit in your wiring repairs, the ECM may not have actually reset when you reset the belt indicator. If that is the case you will need to follow the wiring schematic and make sure everything is connected as specified. I would tend to think that may be the situation if it runs good with the light turned on, but not all the controller regulated features are functional.
This may be a situation whereby you will be money ahead to have a dealer diagnose the codes from the ECM. They will narrow the probable causes and keep you from swapping parts needlessly.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 05-12-2009   #3 (permalink)
richiebanta1
how do you reset the 4wd,i know how to reset the belt light but not the 4wd
Old 07-02-2009   #4 (permalink)
cheeky
Default any luck
I'm having the same problem right now we have tried everthing with no luck.
cheeky is offline   Reply With Quote
Old 07-03-2009   #5 (permalink)
RCW
There is another post about the inability to shift into four wheel drive today. See what I said there and try that.
1979 XS650 Yamaha
New DR-Z400S
08 brute force 750 fuel problems j reitz Kawasaki ATV and Mule 3 08-08-2009 06:46 PM
Brute Force 750 07 vs. 08 slooc1 Kawasaki ATV and Mule 6 04-06-2009 09:48 PM
08 brute force 750 problems slipping 08BF750 Kawasaki ATV and Mule 15 02-02-2009 08:19 PM
My 2005 750 Brute force won't engage 2 wheel drive donnyg Kawasaki ATV and Mule 1 12-20-2008 03:17 PM
Flashing 2wd/4wd on 05 Brute Force 750 Roofgunner Kawasaki ATV and Mule 5 07-26-2008 10:18 PM
