Old 3 Weeks Ago   #41 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
If you add equal lengths top and bottom it SHOULD retain the same camber and caster. It should work fine but seems like an awful lot of work for only 1" extension.
If you only want 1", look into spacing the wheel with an extension. It raises no questions about longevity, camber, or caster. It gets you the desired 1". If you're looking for more than 1" of extension then you'd have to remake suspension arms.
The 400 only has one brake on the right rear... less maintenance but crappy still. I'm replacing the drum brake with the caliper the same as the rear on the mojave. It's a hydraulic foot, cable handle (parking). The original left handlebar parking brake will be retained but the foot brake will be greatly augmented with the disc. My main complaint wasn't how ineffective the foot brake was, but how after a few short hours of riding the parking brake was completely gone. This should remedy that problem.
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
Old 3 Weeks Ago   #42 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
i thought about camber caster i was goin to make a ecentric bolt to move the camber caster by rotating the ecentric bolt .allowin the upper arms to move in and out.of coarse i will have to elongate the oe mountin hole a bit to allow for movement.takein the idea from aligning cars over the years and maybe applieing them to a quad.
i looked into the spacers but didnt like the idea of moveing the wheel further out causein to much load on a spindle.and a risk breakin it off.
the only reason why i really want to do the front 1 in is so i dont have to change the rear axle to a wider one ,just thinkin about gettin a wee bit more stability in the front end.the trails we ride are steep inclines and major ruts and pot holes.and i noticed it wonders and trys to roll on the front.
dang no wonder you had real crappy brakes.only one on the rear?. no wonder you had isues stoppin that 450lb wheeler.on my ole bayou it had dual drum in the front and dual in the rear.i like to see if someone can retro fit disc to the front of these beasts.that would be the cats behind for stoppin power-corey-
Old 3 Weeks Ago   #43 (permalink)
99prairie400
Certain 300's had dual disc in the front and all the 400's did. The front brakes are monsters and they'll slide all four tires but they're not parking brakes...
If it wanders, look at those a-arm mounting bolts. The factory setup was fairly stable if in good shape...
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 3 Weeks Ago   #44 (permalink)
99prairie400
Alright, here are some "nearing completion" pictures. 28" GBC gators, custom floorboards, Superwinch T1000 winch, and over 48" of snorkel.
Oh, just for scale I'm 6'6"
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 3 Weeks Ago   #45 (permalink)
MrGiggles
Never quite fixed.
MrGiggles's Avatar
You're going to need those breaks for them tires. Now that is some meat!
MrGiggles is offline   Reply With Quote
Old 3 Weeks Ago   #46 (permalink)
86klf300guy
any clearence issues turning? man them some monsters hope that engine has the wavos to pull em lol.tell us how they work out in the mud when you get a chance -corey-
Old 3 Weeks Ago   #47 (permalink)
99prairie400
I did have some issues with my footboxes I made but I rectified those. I cut down the front mounting location changed the fender support bracket and made a new front mount for the boxes. Now it's lock to lock with no issues.
I'll be down in the spring to see how these beasts pull. I may try to do a little mudding in a week or two just to see if we're going to have any issues but the water's getting pretty cold out there and I don't like freezing...
Don't the KLF300's have a two speed subtransmission below the regular gearbox? The KLF400 has 5 forward gears but 1st is actually called "SL" or super low. Top speed with the 26" tires was only 4 mph I'm thinking I may actually get up to 5 mph now in SL.
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 2 Weeks Ago   #48 (permalink)
99prairie400
I made plans tonight to take the Prairie and Bayou out tomorrow to some lowlands. I'm going to see how the new tires do. I don't expect any problems, but keep your fingers crossed, I may encounter some water and also some MUD!!! I'll try to take some pics and I'll definitely give yall a blow-by-blow about how well the quad's did.
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 1 Week Ago   #49 (permalink)
99prairie400
It was BEAUTIFUL today here. My buddy and I took both the Prairie and the Bayou out for some muddin!
Here are a few pics:
In the pond. The bottom is mucky and the water is basically the same depth all the way across
Me coming out of the pond:
Uh oh:
Not even with me on the front rack getting those front tires some traction:
Not even with me on the front rack and my buddy on the back rack:
Enough! Throw me the winch cable...
No problem with this hole for either quad:
The best wash ever! The kind I don't have to do:
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 1 Week Ago   #50 (permalink)
86klf300guy
nice .we just went muddin today but i was ridein a eiger 400,man them things suck ,they are so top heavy and when they get stuck (which happened alot) it was a heavy ole beast to lift.the funny thing is my 2x4 300 bayou never got stuck in the places this 4x4 did lol .......i miss my bayou but next year i will have that mojave goin in places where a sport bike shouldnt go lol.....i got to get sum pics for you guys next time im out .....-corey-
Old 1 Week Ago   #51 (permalink)
99prairie400
It's like a guy we go riding with. He has an '08 BF750i. He thought because he had that beefy engine that he'd be able to go anywhere and do anything he wanted. He found out that beefy engine comes with a weight price tag and while that setup can pull tires as big as he wants, the factory skins give up long before he wanted them to. In the end, his weight was a huge hindrance and his engine had way more power than his tires could put to the ground.
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 1 Week Ago   #52 (permalink)
86klf300guy
oh by the way how did that rear disc conversion work out ? was the stoppin power better even with the bigger tires?
that goes to prove one thing, bigger is not always better when muddin or ridein trails. yes the motor and wieght of these machines can cause some pains.in the wallet and on the body when you get em stuck with out havein a winch lol.
Old 1 Week Ago   #53 (permalink)
86klf300guy
one more thing i forgot i found this song off lime wire by colt ford called mud diggers ,its a good song lol thats us to a t lol except on quads ,its a must hear -corey-
Old 1 Week Ago   #54 (permalink)
99prairie400
The disc conversion stopped great. I could hit the rear pedal and stop the entire quad if I wanted to! I'm going to have to adjust it again though. The pedal adjustment is a little too tight I think. It chewed through enough pad on our little ride that the parking brake was out of adjustment when we got ready to go. At least that's easy to adjust. It's just a 12mm bolt in the back of the caliper screw it in another half turn a voila!.
I've been mud digger'd out. The chick who took the pictures found that song a while back and played it probably 100 times in one weekend on a boombox she brought along. My buddy threw the CD out the window on the way home while she wasn't looking.
99 Prairie 400 4x4
98 Bayou 400 4x4
Old 1 Week Ago   #55 (permalink)
86klf300guy
oooooh littering imma tellin lol. i would have aleast played pigeon shottin game with a cd thats been played out lol-corey-
newb, just bought a 250 n i'm havin an oil prob SoK The Mechanics Corner 5 08-16-2005 12:22 AM
Just Bought 91ex500 Kawasaki Streetbikes/Sportbikes 0 06-07-2005 09:33 PM
bought my first bike tistan Kawasaki Streetbikes/Sportbikes 1 05-13-2005 09:01 PM
Brand new here - Just bought a 2003 Drifter 1500 jroskelley Kawasaki Cruisers 13 10-21-2004 11:32 AM
Bought my first bike jaks7124 Main Lobby 1 02-01-2004 10:19 AM
