Old 08-06-2009   #1 (permalink)
okieduc104
Cruising In Fourth Gear
okieduc104's Avatar
Default Long Life DOT 5.1 brake fluid
Anyone using the DOT 5.1 non-silicone long life brake fluids in their motorcycles or Mules?
okieduc104 is offline   Reply With Quote
Old 08-06-2009   #2 (permalink)
RCW
Way Too Much Free Time
I recently switched to SynLube's extra long life 5.1 fluid, but will not have any performance information for at least two years. It was an easy drain and fill, and is supposedly compatible with the OEM fluid, so no complex washing/flushing was required.
But, is it cost effective??? Only time will tell.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-22-2009   #3 (permalink)
Hot Cruiser
Politicians' Nightmare
Hot Cruiser's Avatar
It's time to change the brake fluid on my VN900, and I'm curious about whether other users have used DOT 5 fluid rather than the manual-recommended DOT 4. Searching Kawi's web site about it is a pain. Apart from cost differences, what other factors such as compatibility with internal brake parts are there to consider? Are there any advantages for using DOT 5?
Many thanks!
Jim
'07 Vulcan 900 Classic LT
Jesus is Lord
Hot Cruiser is offline   Reply With Quote
Old 09-22-2009   #4 (permalink)
RCW
The new DOT 5 non-silicone fluids are completely compatible and interchange with the older standards. The silicone based fluids can turn to jelly if the system is not fully evacuated and flushed before you change the fluid.
1979 XS650 Yamaha
New DR-Z400S
Old 09-22-2009   #5 (permalink)
Hot Cruiser
RCW - Thank you for your response and especially for the warning about silicone-based DOT5 brake fluid.
Jim
Jesus is Lord
Heavy Cruisers & Brakes LordGT Kawasaki Cruisers 57 08-02-2008 02:14 AM
rear brake shoe life vmuth Kawasaki Cruisers 0 10-01-2007 07:22 PM
So Long to the Single Life! Svetlana Main Lobby 81 04-16-2007 12:52 AM
Brake Pad Life 1500's toobusi Kawasaki Cruisers 9 08-29-2006 04:12 PM
Brake Fluid & Tires Dawn Ladies Only 15 06-22-2006 06:43 PM
