Old 08-19-2009   #1 (permalink)
thhunt
Question Mule wont run without choke
I have a 3010 Kawasaki Mule Gas. I am having a problem with getting it running. It will only crank and run if I hold out the choke (but runs a little sluggish). The minute I let the choke go it goes dead. I have checked the fuel pump and it is pumping, plugs look good. Checked the intake filter and it looks good as well.Just happened all of the sudden. This happened one time before and I took it to the dealer. All they would tell me about what they done to fix it was gaskets and seals. Is there anything else I can check or look at. It has about 100 hours on engine. Thanks in advance for your help.
Tony
thhunt is offline   Reply With Quote
Old 08-20-2009   #2 (permalink)
RCW
Way Too Much Free Time
Generally, the symptoms you describe are either a situation of improperly adjusted valves, a dirty carburetor, a carburetor that is loose from the intake, or the intake between the carburetor and the engine is loose from the engine.
I would adjust the valves, then totally disassemble and clean the carburetor.
I am not sure what the dealer did to correct such a problem as this before, but the only seals that would cause this are between the carburetor and the engine, and very simple to identify and correct.
I strongly recommend that Mule owners purchase the Service Manual, as it has a very good help section that can walk you through the many items to check and the routine adjustments that are necessary to keep it running well.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-21-2009   #3 (permalink)
thhunt
Thanks for the information. I appreciate your help. I have looked on line for a service manual and have seen some downloadable versions that are a little less expensive. Have you had any experience with the PDF versions of the service manual? Once again many thanks.
Tony
Old 08-21-2009   #4 (permalink)
ruthless59
I have a 650 kawasaki prairie with a running prob. Started all @ once and took carbs off and cleaned. Belt light is flashing and has no power? Belt looks new. It is back firing out both ends.Any help would be thankful.
ruthless59 is offline   Reply With Quote
Old 08-21-2009   #5 (permalink)
ruthless59
Default running problem 650 Kaw Prairie
Any help with this 1???? Back fire out both ends and belt light flashing? Took carbs off and cleaned changed nothing on the running of it.
Old 08-21-2009   #6 (permalink)
ruthless59
anybody out here??????????
Old 08-22-2009   #7 (permalink)
RCW
If you look up the manual discussions on here, you will find the results mixed regarding the PDF versions.
I have used both, and by far prefer the real deal. It is not so much because the PDF manuals are not that good, but more from the standpoint that there are things you run into that the manuals are not that clear about or you find additional information and it is important to be able to write notes for future reference. Also, if I print from my PC printers the ink is not that durable when using the PDF files around any liquids. It is a real pain to have the photo and instructions running off the page because you have moisture on your hands!
Since the Mules tend to outlast several owners, or are used forever on farms and ranches, having the real deal manual with your service notes is pretty helpful.
1979 XS650 Yamaha
New DR-Z400S
Old 08-25-2009   #8 (permalink)
ruthless59
Can anybody sign some light on this problem? Have a 650 Kawaski Praire that acts like it is running out of gas. Belt light is flashing. Belt looks new and have pulled the carbs and clean. Still runs like it is running out of gas?
Old 09-14-2009   #9 (permalink)
cookie_monster
to the OP...
on the 3010, it uses a dual throat carb with a single bowl. They also have idle mixture adjustments on the top, but they're plugged with brass plugs. First thing I'd do is pull the carb off and clean EVERYTHING. Not just one jet or spray some cleaner up inside of it, pull it apart completely (all jets) and clean every single part. Afterwards look through each jet-you should be able to see through each one of them. Also make sure the nozzles are clean-I normally just use the tube of the carb cleaner can and spray it down the air bleed jets in the throat of the carb. This gets 99% of the junk out. Reinstall it and see if it idles ok. If not, chances are you'll have to drill off the plugs and adjust the air/fuel mixture.
Next question on the 650 Prairie. Is the engine limited to where it will only go about 7 mph in high range? Sounds like the belt failure switch has been tripped. When it's tripped the CDI limits engine speed but cutting the spark intermittently, which makes it backfire.
cookie_monster is offline   Reply With Quote
I.D.'ing a 3010 Mule questions okieduc104 Kawasaki ATV and Mule 17 08-12-2009 05:55 AM
My 3010 Mule won't run reliably missioncritical Kawasaki ATV and Mule 5 04-23-2009 12:07 AM
98 Mule 2510 4x4 no start? Dieselfixer The Mechanics Corner 0 02-02-2009 09:52 PM
Strange Mule problems Need help.... RandellH Kawasaki ATV and Mule 5 12-19-2006 08:25 PM
Ninja starts but wont run without choke mark The Mechanics Corner 5 09-27-2005 08:31 AM
