Old 09-13-2009   #1 (permalink)
604
Default Mule 4010 Diesel Rear Drive Shaft Guards???
I was looking at getting the factory rear drive shaft guards for my 4010 Diesel, but saw they say they only fit the gas mule. Any one ever try to put them on a Diesel?? I am not afraid to do a little cutting or grinding on them to make them fit. Even cut down to fit, a little protection is better than no protection! I figure it must be a clearance thing. Thanks for any help!!!
604 is offline   Reply With Quote
Old 09-13-2009   #2 (permalink)
RCW
Way Too Much Free Time
The transaxle, frame, and rear drive shafts are the same for both the gas and diesel versions. The gas unit should fit just fine.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-14-2009   #3 (permalink)
604
Thanks RCW,
That is what I thought. But Kawasaki has a note on there web sight that they do not fit the diesel. Go figure?
Old 09-21-2009   #4 (permalink)
604
Just to let any one know that may want to put the rear guards on a diesel mule. They bolt right on just fine. But you need to cut about 2in off at an angle on the end-top of them. Or they will hit the transmission on the RH side, and hit the belt housing on the LH side when the suspension compresses. The diesel engine and transmission is much wider than the gas. Just make shure you take off enough. A little bit of a pain but well worth it for the added protection.
3010 diesel stripped rear hub Gorlist Kawasaki ATV and Mule 2 07-06-2009 07:07 PM
Shaft Drive Versus Belt Drive Vulcan900 Kawasaki Cruisers 21 05-30-2009 09:32 AM
Will Mule 4000 rear shocks/ springs fit a Mule 600/ 610? DrPeeb Kawasaki ATV and Mule 2 05-12-2009 05:09 PM
2008 diesel trans mule grizzly2c Kawasaki ATV and Mule 3 03-07-2008 11:14 AM
chrome drive shaft cover dickwol Kawasaki Cruisers 3 09-22-2004 02:20 PM
