Old 09-14-2009   #1 (permalink)
220bayou
Default bayou 220 ignition switch?
hi,
i am looking at a few ignition switches/keys on ebay. my bayou 220 is a 97 model, what is odd i have found a few switches that claim to be from a 97 model some have 4 connecting wires and some with just the brown and white wire. my clymer manual shows 4 wires should be on my model,however there is only the brown and white on my machine,why would there be a different igntion switch out there? there was no ignition switch on my atv,as it had started being parted out when i bought it.
thanks,Bill
220bayou is offline   Reply With Quote
Old 09-14-2009   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
hello i use a lawn mower ignition switch and i have a brown and white wire on a 5 blade switch.just have to find the combonation that works to turn it on and off.7.00 $ vs 20.00 i went with seven lol -corey-
Old 09-14-2009   #3 (permalink)
MrGiggles
Never quite fixed.
MrGiggles's Avatar
A toggle switch will work fine as well. White is the hot wire so make sure it doesn't touch ground. Same with the brown.
MrGiggles is offline   Reply With Quote
Bayou 220 Ignition problem jdt425 The Mechanics Corner 0 04-01-2007 11:48 AM
Track bike help JP 636 The Mechanics Corner 5 02-08-2007 02:47 PM
Ignition switch question metalesp Main Lobby 6 08-29-2006 06:46 PM
Ignition switch question metalesp The Mechanics Corner 1 08-26-2006 02:17 AM
removing the ignition switch help buckjflowers Kawasaki Streetbikes/Sportbikes 0 06-07-2006 07:26 PM
