Old 09-19-2009   #1 (permalink)
220bayou
Default 300 ignition switch on a 220?
would the igntion switch from a 300 bayou work on a 220? the 300 switch only has the brown and white wire,not the two other accessory wires as the 220.
Bill
220bayou is offline   Reply With Quote
Old 09-21-2009   #2 (permalink)
zeek123
Finally Got Into First Gear
zeek123's Avatar
well all you have to do is find the live and the ground wires and it should work
zeek123 is offline   Reply With Quote
Old 09-21-2009   #3 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
yeap same switch is used in both-corey-
bayou 220 ignition switch? 220bayou Kawasaki ATV and Mule 2 09-14-2009 04:39 PM
88 bayou 300 motor on a 220 frame? moparfan1234 Kawasaki ATV and Mule 0 07-19-2009 12:23 PM
Ignition switch afojc The Mechanics Corner 4 05-10-2009 10:19 PM
Fan switch question rd3500 The Mechanics Corner 3 10-15-2007 03:31 PM
removing the ignition switch help buckjflowers Kawasaki Streetbikes/Sportbikes 0 06-07-2006 07:26 PM
