Old 09-20-2009   #1 (permalink)
softrdr
Default drum seal
what type grease should i use on the rear brake drum seal on a 1997 klf300. repair book sayes noktopas jl152 low temp, where can i find or is there another. thanks wayne
softrdr is offline   Reply With Quote
Old 09-20-2009   #2 (permalink)
RCW
Way Too Much Free Time
The suitable greases are Mobil Polyrex EM, Amoco’s RYKON
Premium #2, Texaco's Polystar B, Chevron SRI #2 grease, or
EXXON’s Polyrex. Do not use the “EP” versions of these
greases as they contain materials that harden with dirt and water exposure, and will scrub the seals.
Any Hydrotex grease will also work.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-20-2009   #3 (permalink)
softrdr
thanks for the help
Shift drum on a 03' KX85 hairbear65 Kawasaki Motocross and Offroad 12 17 Hours Ago 11:28 PM
84' KZ550 Oil Seal Replaced 84_KZ550_NewB Vintage Motorcyle Info 3 06-19-2008 11:35 PM
What Holds the Valve Stem Oil Seal? Alizard The Mechanics Corner 4 09-17-2007 02:26 PM
Tach seal leakage rlibby Vintage Motorcyle Info 4 03-06-2007 02:12 PM
Navy Seal grunt Off Topic 11 09-23-2005 10:52 PM
