Old 09-21-2009   #1 (permalink)
pwain
Default 1994 Bayou 300
can anyone give me the torque for the head bolts on this machine? Many thanks
pwain is offline   Reply With Quote
Old 09-21-2009   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
if i remember right its like 30ft lbs give or take a lb.and you use a criss cross pattern to tighten.i start at 5lbs of torque and work up to final spec.after all its aluminum.even torque is key to not warp that head .-corey-
Old 09-23-2009   #3 (permalink)
stu#71
corey is correct.
First stage
main bolts: 11 ft lbs
small bolts: 52 inch lbs
Second stage
main: used 22 ft lbs, new 25 ft lbs
small: 104 inch lbs
use non perm thread lock
stu#71 is offline   Reply With Quote
Old 09-23-2009   #4 (permalink)
pwain
Thanks to both of you, just what I needed.
88 bayou 300 motor on a 220 frame? moparfan1234 Kawasaki ATV and Mule 0 07-19-2009 12:23 PM
torn Boot on the rear drive shaft 88 300 bayou naolssloan Kawasaki ATV and Mule 7 04-27-2009 01:07 AM
Kawasaki prairie 300 1999 mag wheel help reisset Kawasaki ATV and Mule 0 11-06-2008 10:09 AM
Bayou 300 CDI, Regulator, & Carb SteveS Offroad Buy/Sell/Trade 2 05-16-2008 11:20 PM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
