I have a 99 prairie 300 that is missing the carburetor. Should i look for a replacement kawasaki carb, or something else. i read on here about the trx carburetor, but that was on a bayou not a prairie, will the trx carb work on the prairie also? any help will be greatly appreciated, the kids are getting tired of waiting on me.
Way Too Much Free Time
There are two carburetors worth considering, Mikuni or Keihin. The Keihin is OEM to Kawasaki and Honda, and is actually manufactured by Honda.
The key to finding a carburetor that will work properly is the size of the carburetor venturi and the proper jetting for your application. If I am speaking Greek, then I would recommend you just purchase a new OEM carburetor from Kawasaki. It will save you a ton of pain. If I am not speaking Greek, then you now know all you need to select a replacement carburetor. As far as quality of carburetors go, I prefer the Mikuni. It has replaceable needle seat and valve for the float. The Keihin carbs are a throw away if the float needle seat is damaged or worn out. Used Keihin carburetors are almost always a waste of money as the seat is damaged and some one is looking for a sucker. Used Mikuni carburetors always sell for a premium, but you have to watch for bad diaphragms and other costly parts that could easily put you at the new price by the time they are replaced.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#4 (permalink) |
Thanks for all the information. I finally got hold of the guy who tore down the bike originally and he had the old carb setting under the workbench in a box. I think i am going to start with it since i already have it and if i cannot get it to work then try another, again, thanks.
| 2000 Kawasaki Prairie 300 4*4 rev problem | arsondog2 | Kawasaki ATV and Mule | 0 | 06-29-2009 09:24 AM |
| Need Help-- Prairie 300 | Huntin Nut | Kawasaki ATV and Mule | 1 | 08-13-2008 07:19 PM |
| Need advice on 89 kx 125 carb | Cmitro | Kawasaki Motocross and Offroad | 0 | 05-09-2008 03:24 PM |
| 98 300 Bayou carb adjustments | Nick8564 | Kawasaki ATV and Mule | 2 | 03-27-2007 05:53 PM |
| Kawasaki Prairie 300 4X4 | Thingie | Kawasaki ATV and Mule | 2 | 03-27-2007 10:44 AM |
