LinkBack | Thread Tools |
Finally Got Into First Gear
hey i changed the woodruff key on my bike its a 89 bayou 220 but now the motor wont turn over what did i do wrong the motor was turning over fine when i put the rachet and socket on the bolt but now it wont turn over please help me
Way Too Much Free Time
I would suspect you rolled the engine over backwards and flipped the cam chain off one of the sprockets and have either bound the crankshaft or have locked a valve into the piston when the cam was no longer timed properly.
But, also check to be sure you did not leave a chunk of the old key in the flywheel that is now stuck to the magnet and dug into one of the alternator coils. If it is not a chunk of old key, go to your service and repair manual and check the section that covers the cam and cam chain. It will walk you through the tear down and repair.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#4 (permalink) |
so RCW if i that the timing chain off the should the motor turn over and yes the motor did roll back is this bad and i dont have a manual for the bike and if i locked on of the valves into the piston what do i have to do
#5 (permalink) |
What happens can be one or both of the following:
The timing chain rolls off and winds around the crankshaft drive sprocket or just binds along the cam sprocket. The timing chain rolls off and the camshaft no longer turns and the piston drives a valve into the piston crown when the engine turns over and the camshaft does not maintain timing. Never roll a four stroke engine the wrong direction. Camshaft lobes are ground with acceleration ramps and then a different profile on the release side of the lobe. Rolling one backwards without it being very well oiled can damage the cam or a rocker arm. If the cam chain has not been serviced and is loose, driving the chain backwards allows slack to build up on the off side and roll the chain off a sprocket.
#11 (permalink) |
its hard to lock a valve .just take that caes off and the cam gear inspection plate and the chain tentsioner back off and start over.
use a 15mm socket to rotate the engine over on fly wheel bolt when you get the chain undone from its bind to time the machine and you may want to get another set of paws to help you out in the timin off the engine .one will hold the fly wheel bolt at the (Tmark) and the other set of hands hold the chain up and move the cam gear to its mark .then put the tentsioner back in and adjust it.while holdin all the timin componets still with the socket on the fly and a socket on the cam gear.thisds will help out with the marks not moveing when tentsion is applied to the chain. |
#15 (permalink) |
2 10mm bolts on the tent remove em and then turn and pull out the tentsioner.then take the chain now that its slacked and put it on the cam gear after you line up the timin marks.use your other set of hands to hold the chain tought so it will roll with the engine while your turning it to get the marks on the fly lined up .then use a socket on the cam gear and roll the timein mark up for the cam .then put the chain over the cam while holding everything still .then put the tent back in and snug the 2 10mm bolts to 15 ftlbs of torque.theer is a bolt on the back of the tent while its out loosen it and push the plundger back in and tighten the bolt.when you have the tent back in loosen that bolt again and it will release that tent plundger and the chain will tighten up.snug that bolt back down.-corey-
#16 (permalink) |
hey thanks for all the help 300guy i got everything all back together and she truns over nice now i just have to find a socket to fit the plug friggin thing would have to be a odd size but i glad that you could help me
| My turn at putting my bike down. | sihing_steve | Main Lobby | 15 | 05-31-2006 10:25 AM |
| Magic key to new HD | samuel | Off Topic | 17 | 12-23-2005 07:56 PM |
| Spedo Moving/Not Moving on Key Turn | RampRat | Kawasaki Cruisers | 2 | 09-07-2005 10:24 PM |
| steering lock issue, wont turn to left but parking lock works | inlikefletch | Kawasaki Streetbikes/Sportbikes | 2 | 03-23-2005 01:40 AM |
| Kuryakyn Turn Signal Mirrors on 04 Mean Streak | 04Meanie | Kawasaki Cruisers | 5 | 08-25-2004 12:37 AM |
