Old 09-26-2009   #1 (permalink)
zeek123
Finally Got Into First Gear
zeek123's Avatar
Question can someone help me
i changed the woodruff key in my 89 bayou 220 and now the motor will not turn over what should i do please please help me the motor did roll back when i put it back together if that helps with anything
zeek123 is offline   Reply With Quote
Old 09-27-2009   #2 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
What was the reason for changing it in the first place, that may tell us a lot?
Was it changed with an offset key to advance or retard it?
Or did it somehow break, causing the quad to die, and requiring its replacement?
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Old 09-27-2009   #3 (permalink)
zeek123
zeek123's Avatar
never mind northernman i fixed it i had a bind in mt timming chain and the motor wouldnt turn over so i had to take it apart again and get the bind out of the timing chain than had to put it all back together and now everything it working fine............... the reason i had to take it apart in the first place was because the woodruff key sheared off
Old 09-27-2009   #4 (permalink)
northernman
Glad its fixed Zeek.
Old 09-27-2009   #5 (permalink)
zeek123
zeek123's Avatar
me too now just have to get a socket to fit the dam plug its a odd size
Old 09-27-2009   #6 (permalink)
northernman
Spark plug?
It could need a thin walled 13/16 ???
Old 09-27-2009   #7 (permalink)
zeek123
zeek123's Avatar
no its a thin walled 3/4
Old 09-27-2009   #8 (permalink)
northernman
Thats common, I thought you said it was special.
Some have used, although not common a 13/16.
I have a near museum piece old Mercury 292 sled that has a 13/16 plug size.
