Finally Got Into First Gear
after getting everything all back together on my 89 bayou 220 and got it timed now i have no fire its a new plug and there is nothing not even a hint
Way Too Much Free Time
$64 question: Were you cranking it over with the key on , the plug out, the ignition coil connected, and no spark plug connected to the ground?
If so, you need to diagnose the ignition module, as it is likely fried. If you do not have the service and repair manual you will save yourself a lot of time and money getting one and following the processes outlined.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#6 (permalink) |
have you checked the fuse at the solinoid if its blown push button start will not work and youll have no spark due to lack of power goin to coil and pulser.
also check by the battery for a fuse .it will be a inline fuse to the positive side of the battery.just follow the main power line from the battery terminal and look for a inline fuse holder.(note sum have them sum does not).but look at the stater soliniod for the fuse it is part of it.-corey- |
| Red Lodge Mountains up in Smoke! | kawibabe | Off Topic | 38 | 07-31-2008 11:24 AM |
| Time flies... 5th anniversary of Great White fire | CycleDude | Off Topic | 0 | 02-20-2008 09:04 AM |
| Women arrested for killing cyclist and starting fire. | metalesp | Off Topic | 55 | 11-23-2007 05:34 PM |
| Fire destroys Johnny Cash's lakeside home | D-Day | Off Topic | 20 | 04-12-2007 02:52 PM |
| Fire, gas release at chemical plant forces thousands to evacuate in Apex, NC | D-Day | Off Topic | 5 | 10-07-2006 07:42 PM |
