Old 09-29-2009   #1 (permalink)
MartinD
Default New member with rod bearing question
I am having to rebuild my 2006 750 brute force and notice on some online stores it shows 3 different listing for rod bearings based on color????? What is the deal?? Thanks in advance for any info.
MartinD is offline   Reply With Quote
Old 09-29-2009   #2 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
maybe the "red is faster" factor?
I've not seen that before. However, we all want to know why you're rebuilding a 2006 model! ;-D
NCDave
Our Lady of Blessed Acceleration, don't fail us now. - Elwood Blues
http://www.bikepics.com/members/ncdave/
NCDave is offline   Reply With Quote
Old 09-29-2009   #3 (permalink)
RCW
Way Too Much Free Time
The color coding is for standard and undersize options, as determined by the finished size of the crankshaft throws after machining.
When you do rebuild one of these be sure to follow the manufacturer's guidelines for turning the crank. Any good motorcycle machine shop or Kawasaki dealer will have these and then will be able to tell you the size bearings you will need.
If the old bearings were scuffed at all, it will be necessary to carefully mic the crank throw and make sure it is perfectly round and within tolerances. If not then have the crank turned or you will cough the new bearings very quickly. If the old bearings were not scuffed, and the crankshaft is not damaged, then reuse them exactly where they were installed in the first place.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-29-2009   #4 (permalink)
MartinD
Im installing a new crank and rods. Its hammering pretty good. I "loaned" it to my cousin and she and her friend soaked in the mud and kept running it.
Old 09-29-2009   #5 (permalink)
MartinD
I found this and it looks like a good deal
BRUTE FORCE 750, PRARIE 700, KFX 700 CRANKSHAFT & RODS:eBay Motors (item 280402837902 end time Oct-07-09 21:25:44 PDT)
Old 09-29-2009   #6 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
If you have the $399 for the crank and rods (and need the rods) That's probably not a bad deal.
I tell you who you need to call (because he specializes in KFX700 engines and probably has the parts on the shelf) Mickey Dunlap of Welcome to Four Stroke Tech.net!. He rebuilt my Prairie 400 crank for me and had it back in a week. The LDS wouldn't even touch it...
99prairie400 is offline   Reply With Quote
Old 09-29-2009   #7 (permalink)
RCW
I am skeptical of anything that is not guaranteed new OEM on ebay. I have just seen to many guys show up with ebay special parts that are the same quality as used toilet paper! I have to throw them away and start over, and then usually have to repair the damage the junk parts caused in addition to what was originally broken.
On the higher performance engines the additional damage can add a thousand or more to the price of a repair. The good deal turns in to a real sewer frog.
1979 XS650 Yamaha
New DR-Z400S
Old 09-29-2009   #8 (permalink)
MartinD
Thanks RCW, i think you are right. Im gonna wait and get the engine tore down and see whats going on. Are these engines a pain to get out?
Steering Stem Bearing Removal Norseman10 Vintage Motorcyle Info 10 05-23-2008 12:50 AM
Motor or bottom end w/ rod needed for 98 Mojave KSF 250 indirocz28 Kawasaki ATV and Mule 2 05-18-2008 12:10 AM
New Member intro & question Timbee732 Main Lobby 8 07-25-2007 10:59 AM
Need an engine for a 98 Mojave KSF 250 - or just bottom end w/ rod?? indirocz28 The Mechanics Corner 2 07-10-2006 04:50 PM
New Member with a question regarding insurance.... kuzals Main Lobby 12 01-16-2004 04:15 PM
