Old 10-08-2009   #21 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
clutch springs?
Old 10-08-2009   #22 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
#1 I thought amish people signed off all contact with technology, including internal combustion engine.
#2 I broke my Prairie 400 in HARD with great results. Read this article:
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
I did hard pulls in my driveway for three days. Warm it up to operating temperature and then take off like a madman, slam on brakes, turn around and pull the length of the driveway again.
#3 The one-way clutch on the outside of the primary is slipping. If it were the secondary it wouldn't matter if you revved it up, it would still slip. If it were the primary clutch slipping, it would slip when you are in upper gears pulling at the lower RPM's.
99prairie400 is offline   Reply With Quote
Old 10-08-2009   #23 (permalink)
MrGiggles
Never quite fixed.
MrGiggles's Avatar
Originally Posted by 86klf300guy View Post
clutch springs?
You'd think if a spring was fatiguing it would take off with no throttle and stall if you try and stop it.
There is a whole Amish/Mennonite community around here that uses gas engines. They even run a discount Grocery store.
I will probably do that. I read that earlier but didn't know what to think.
I can't seem to figure out why it only slips when the wheels try to drive the engine faster than it is running, and not when pulling.
MrGiggles is offline   Reply With Quote
Old 10-08-2009   #24 (permalink)
86klf300guy
99 that break in procudure is up in the air.many people have differeent ways of doin it.but i will stay with the way i was tought by gm and a champion drag racer.a slow break in and fattin the fuel mix to keep the cylinder temps down lets everything expand and contract slowly ,not quickly to seal um up.
have you ever been to a drag race with nitro funny cars.and stand there and watch em rebuild there engines?ounce they are done rebuilding them they fire em up and idle em.but if you happen to stand behind one while they are breakin in the engine your eyes will burn due to how rich they are runnin the fuel.and they are makin 5000+ horse on a normal break in.
as that page you displayed you can lose 2-10% horse by breakin in normal or slow.and 2-10 horse gain by a speedy breakin.
i will stick to ole school methods on this one.because its been workin for many years.and look how long the piston and rings last there.
as for that page they rebuild there motors every year not every 5 - 10+yrs
like quds and motor cycles if they are properly maintenced.
not tryin to start a conflict or nothin its just preference's on how to properly break in new engine/rings-corey-
Old 10-10-2009   #25 (permalink)
MrGiggles
Never quite fixed.
MrGiggles's Avatar
I've got about 3hrs of ride time it and the more I ride it the higher the compression gets and it get more power. I can't even pull-start it with one arm anymore. My starter is iffy so I don't have my starting system put back in yet.
Old 10-11-2009   #26 (permalink)
86klf300guy
cool . ounce you have reached that max compression make sure to change your oil &filter.
hows the smokeing has it stopped all together?or does it puff a little still?
on them 3 hrs have you beat it or just cruised with it?
i just started the tear down of my mojave now i will post some pics as soon as the wife helps me out again -corey-
Old 10-11-2009   #27 (permalink)
MrGiggles
Never quite fixed.
MrGiggles's Avatar
I plan to.
The smoking stopped altogether, just a little bit after the first start from the teardown.
Just cruised and played with it lightly. Never going over 1/2 throttle, varying-speed mud donuts, etc.
88 bayou 300 motor on a 220 frame? moparfan1234 Kawasaki ATV and Mule 0 07-19-2009 12:23 PM
bayou 220 stator, pre-1996 trade/buy read! farmereinar Accessory Swap Meet 3 06-17-2009 06:00 AM
lift kit for 220 bayou lonestardjb Kawasaki ATV and Mule 4 09-07-2008 10:58 PM
Bayou 220 carburetor clip position. Help! mdgil Kawasaki ATV and Mule 1 04-18-2008 09:20 PM
Bayou 250 motor or 220? Matt R Kawasaki ATV and Mule 5 01-07-2008 09:18 PM
