LinkBack | Thread Tools |
Never quite fixed.
My Bayou has been consuming oil pretty bad and has gotten to the point where oil was coming out of the tail pipe, meaning I had to do something. I was originally just going to change the head gasket, but have decided to change the rings too. I have torn it down, and taken pics of the process. I'm waiting on the rings to get here now.
Something was up. ![]() Before ![]() A half hour later ![]() Pics of the Cylinder/Head ![]() ![]() ![]() ![]() ![]() I did pull the jug off, and everything looked good. No scoring or broken rings. |
Way Too Much Free Time
i see yoo finally tore into it huh.....if it were me id have the jug checked by a machine shop to make sure its not tapered or out of round.if that is ok then have it measured to make sure your jug is not allready been boreed out so you get the correct rings.
and if its not over sized etc id still have the jug honed so the new rings will seat properly.also make sure you index theh rings correctly and (end gap them) so they have the correct gap for expansion and contraction. if you happen to take it to a machine shop and they say it needs bored say 10 over then youll have to cancel the ring order and order a wiseco piston kit that comes with new rist pin and clips piston and piston rings. are you doing the valves seat and guides also?if so make sure you relap the valves when you pull em out ,this will save you alot of headaches down the road.as my dad allways says if its worth doin it worth doin it right the first time to save you heart aches down the road.plus you get the satisfaction of knowin that you will not ahve any problms for like 5 - 10 years if you take care of it and not red line it alot keep us posted with pics mr gigles on the rebuild good luck and if you have any questions we will be here to lean on lol-corey- |
#3 (permalink) | |
Never quite fixed.
Just the seals, I don't have the parts nor money to replace them. How hard are the valves to take out? Can a get by with a screwdriver like a Briggs engine? |
#4 (permalink) |
iv used vise grips to push the outer ring down to remove the keepers.
what kinda hone do you have a ball hone or a flat stone?i rec the ball hone style for this operation.but that will not help if that cylinder is out of round or tapered.if you have a dial indicator with a rollore on the end of it and its mounted to a rod you can check that your self.but its best left to a shop. i just worry you put your new rings and gaskets on it and it will all be for nothin.cause it will not seal up.then your back to square 1 and out more $$$$$$$ cause youll have to then do this way.i know money tight brother i have a mojave that needs a new piston and rings now.and it is waitin for me to get all the parts.i bye piece by piece then when i have em all it goes back together right. |
#5 (permalink) | |
Never quite fixed.
It has flat stones. There is a local Amish guy who repairs small engines, I will bring it to him and see if he can help me out. If my rings come today then I will try and get pics of the piston and rings on it. |
#13 (permalink) | |
#14 (permalink) |
for tat cam bolt use an impact gun and if it will not budge still get a propane torch out and heat that bolt up just a little to free up the loc tite and then just hold the gear with a wedge of wood and use the impact gun to free it and i think that bolt is a lefty not a right,so righty lossy lefty tighty.not righty tighty lefty lossy lol-corey- d-_-b
#15 (permalink) | |
Never quite fixed.
I did notice on the head that there are two jagged holes on each side behind the cam gear. I'm guess they're there for oil to run back down to the engine, but they are not smooth and stock-looking. Am I correct? |
#16 (permalink) |
Never quite fixed.
Yesterday I was able to get the cylinder honed and the new rings installed. Between then and now I have gotten it put back together. It has good compression, doesn't smoke anymore, and runs great.
Does anyone know what the break-in procedure is for the new rings? I ran it for 10 minutes lightly without issue today. |
#18 (permalink) |
break in take afew hrs at low rpms and never rev it out and or hold a rpm to long.change up the rpms while rideing.do not open the throotle all the way for at least hrs of break in.after 8 hrs of break in change the oil and filter and have fun.-corey-
#19 (permalink) |
i just bought my buds 250 mojave that needs a total top end i will post pics of the rebuild as i go ....as soon as i get to it ne how lol...its goin to cost me 348.. to rebuild it no includeing the machine shop charge to bore it out.imma makin it a 280ccwith 11.5 comp and haveing the cams done up to match.new timin chain, guides,intakes and exhaust valves,springs,guides and sealsmight have the head milled down if i got the clearence.or just cut some eyebrows in the piston to give me some room for valves to clear.its goin to fast
#20 (permalink) | ||
Never quite fixed.
That sounds like a good time. Unfortunately I've never really rode a fast quad. Just utilities. I have another question. Recently it started making a new noise. As soon as you shut it off, there is a whirring noise followed by a clunk. It sounds like something is spinning but is stopped abruptly. At the same time this started I also notice the clutch is slipping, but only when the engine is braking the wheels. You ride down a hill at idle, then the clutch seems to disengage and the quad free-wheels down the hill. It will kick back in if you rev the motor. Any ideas? |
| 88 bayou 300 motor on a 220 frame? | moparfan1234 | Kawasaki ATV and Mule | 0 | 07-19-2009 12:23 PM |
| bayou 220 stator, pre-1996 trade/buy read! | farmereinar | Accessory Swap Meet | 3 | 06-17-2009 06:00 AM |
| lift kit for 220 bayou | lonestardjb | Kawasaki ATV and Mule | 4 | 09-07-2008 10:58 PM |
| Bayou 220 carburetor clip position. Help! | mdgil | Kawasaki ATV and Mule | 1 | 04-18-2008 09:20 PM |
| Bayou 250 motor or 220? | Matt R | Kawasaki ATV and Mule | 5 | 01-07-2008 09:18 PM |
