Old 10-02-2009   #1 (permalink)
PIG 116
Default Carb, CDI, Regulator Problem on Bayou 300?
2001 Bayou 300 ran great and then these things happened. Started hearing louding ticking coming from the front, but still ran fine. Battery was replaced because old one died. Then all off a sudden it bogs under heavy throttle making a loud noise through the carb/ airbox. Starts and idles fine but will function under heavy throttle. I took the carb off and cleaned it, I don't think that was the problem. Any ideas would be appreciated.
PIG 116 is offline   Reply With Quote
Old 10-02-2009   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
hello ,,,,,,hows the oil level and or oil,has it been changed lately?also may want to check valve lash and or the valve adjuster screws for backing out.look at the rocker arms for cracks etc.
look at those first and post your findings we will go from there.-corey-
Old 10-03-2009   #3 (permalink)
PIG 116
Oil is due for changing but the level is fine, I suppose I will need to order a manual. Where is the best place to download a manual online
Old 4 Weeks Ago   #4 (permalink)
indmech69
Hey i may know what your problem is. Do you ever adjust your cam chain slack? if not there is a good chance you may have jumped your timing chain a knoch, your bike's timng may now be slightly retarted(that is a technical term) in that case it will idle fine but will pop out the carb when excellerated.
The other thing may be you regulator/rectifier they can make some noise if they explode, this can also cook your battery and if the plug in is fried on the regulator the cdi might not be getting the proper voltage resulting in a weak spark not capable of sustaining more than an idle
hope this helps
indmech69 is offline   Reply With Quote
300 Bayou carb problems codeman3822 Main Lobby 0 11-01-2008 06:33 PM
Yet another Bayou 300 that won't start..... markdrury Kawasaki ATV and Mule 14 10-26-2008 04:53 PM
91 Bayou 220 carb needed mrbleegs Kawasaki ATV and Mule 10 07-27-2008 10:41 PM
96 Bayou 300 won't run above idle scottjima Kawasaki ATV and Mule 6 02-11-2008 07:30 PM
firing on a bayou 300 pcdoc65 Kawasaki ATV and Mule 15 08-13-2007 08:14 PM
