Old 10-05-2009   #1 (permalink)
ancy
Default Got a Mule Moving
Well i got the fuel pump in one of the mules and it took right off. Now there is gas coming out of black tubes at the bottom of the carbs. Are these just drains? Is the fuel pump to much? Thanks
ancy is offline   Reply With Quote
Old 10-05-2009   #2 (permalink)
RCW
Way Too Much Free Time
Multiple carbs and multiple tubes, it must be the 1000. Anyway, it is either stuck floats or float valves, or fuel pressure over 3-4 psi.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 10-06-2009   #3 (permalink)
ancy
The two 3mm allen screws at the bottom of the carbs were lose. It looks like these are drains of some sort. Tightened them up and the leak stopped. I also think the pump I bought is like 4-7psi, but not seeing any more leaks or any thing coming out of the over flow. Will this over presser hurt any thing? Thanks
Old 10-06-2009   #4 (permalink)
RCW
No, not as long as there is no flooding. The only thing that can happen is the pressure forces the float needle out of its seat, and then you would have flooding. No flooding, no problem!
1979 XS650 Yamaha
New DR-Z400S
How to SECURE / LOCK MULE ???? GooMULE Kawasaki ATV and Mule 6 08-27-2009 01:42 PM
I.D.'ing a 3010 Mule questions okieduc104 Kawasaki ATV and Mule 17 08-12-2009 05:55 AM
Getty Up Mule Speed Kit Review mattm Kawasaki ATV and Mule 12 09-19-2007 03:15 AM
having trouble with my mule boltzojoe2 Kawasaki ATV and Mule 8 06-12-2006 04:09 PM
