Old 10-05-2009   #1 (permalink)
Jharris2921
Default 2005 Kawasaki Prairie 4x4 problems
Hey guys hows it going. I am new to the site as you can tell but I own 2 Kawasaki's, A Ninja 500 and a 2005 Kawasaki Prairie 360 4x4. The problem with the fourwheeler is that the 4 wheel drive doesnt seem to be kicking in. i checked the front differential and it was a little bit of a mud color, im kinda a mud ***** . But I was wondering if I could get some help on why it isnt working. It worked right before i went four wheeling with the buds yesterday, but after the ride it didnt work and I didnt even touch it throughout the ride.
Thanks
-Justin
Jharris2921 is offline   Reply With Quote
Old 10-05-2009   #2 (permalink)
RCW
Way Too Much Free Time
If the front differential oil is mud colored, you are due for a tear down to clean it out and see if the bearings, gears, and friction plates can be salvaged.
The usual cause of the front drive not engaging is the belt wear indicator getting slapped and triggering the warning light.
The next most common cause is failure of the front shift motor or a torn or loose wire. If the front diff lube is muddy, I would suspect the shift collar is galled and stuck and the shift motor has burned out.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** Spok Kawasaki Cruisers 170 12-12-2006 06:12 PM
