Old 10-10-2009   #1 (permalink)
SEA_ArcheryGuy
Default 02' Prairie 650 Battery Issue
Im looking for some guidance here, anything will be better than what I know.
On my prairie 650, I have installed a brand new battery. Within 3 ride on the battery it was completely dead. I can fully charge it and it will be dead again the next day. Any suggestions? I would guess that it was the stator, but it will go dead without me even riding it. Possibly grounding out somewhere/
Please help me with this.
Thank You in Advance...
SEA_ArcheryGuy is offline   Reply With Quote
Old 10-11-2009   #2 (permalink)
RCW
Way Too Much Free Time
I believe the 02 has a diagnostic port. If so, take it to the dealer and pay for the diagnostic to locate the problem. It is far quicker than doing it with a multimeter.
If you want to do it yourself, your best bet is to disconnect the battery and all the electrical accessories and start diagnosing the wiring and components with a good digital multimeter.
Carefully follow the service manual instructions for checking the solid state components so you do not damage them, but everything else is just a matter of looking for continuity and ruling out shorts or open circuits.
I would guess you will locate the problem yourself within just a few hours to maybe a couple of days, based on your confidence level.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 10-11-2009   #3 (permalink)
kawracr
5150
Check to make sure the voltage regulator is plugged in. It is located above the right rear wheel. It is the black box with fins on it. I have seen them being unplugged before. If you ride in alot of mud the weight of the mud hanging on the wires will unplug the connector.
kawracr is offline   Reply With Quote
Old 10-12-2009   #4 (permalink)
SEA_ArcheryGuy
Thanks Alot Guys.
Any other help is greatly appreciated.
I'm going to look at the voltage regulator this afternoon..
Old 10-12-2009   #5 (permalink)
86klf300guy
86klf300guy's Avatar
could be just a bad battery of the self?have it checked.
why was he reason for te battery change in the first place.was it goin dead like the new one?or was it time for a new one?
Old 10-12-2009   #6 (permalink)
SEA_ArcheryGuy
Yes, the reason for the battery replacement was that it would not hold a charge. The exact same thing that this one is doing.
02 Prairie 650 Not Turning Over Hammer9 Kawasaki ATV and Mule 10 10-10-2008 03:01 PM
2003 650 Prairie help bill56 The Mechanics Corner 0 10-03-2008 12:47 AM
WTB: Oil Pressure Switch & Fuel Level Switch for 81 KZ-750 Little B Streetbikes Buy/Sell/Trade 0 12-11-2007 01:10 PM
Prairie 650 front end whining rather loudly valholler Kawasaki ATV and Mule 1 11-16-2004 10:52 PM
prairie 650 power loss turnerman The Mechanics Corner 16 10-21-2004 10:15 AM
