Old 10-11-2009   #1 (permalink)
gcoultas1
Default Witch winch for a mule trans
I have a 3010 trans gas and am looking to get a winch for it and need some help on deciding. First what rating will a 3000lb be sufficient or should I move up to a 4000lb class. Next the brand, I know that Warn is top, but the price has me deterred. If it really is worth spending the extra money the ok, but will a cheaper one do the same thing. I have been looking at Mile Marker PE4500 and even the Venom 4000lb model. Now don’t blast me to much but I don’t want to spend an extra $200 if I don’t need to.
gcoultas1 is offline   Reply With Quote
Old 10-11-2009   #2 (permalink)
RCW
Way Too Much Free Time
I have no problem with the bargain winches at all, so just get what does the job. Remember the rating on a winch is at one cable wrap on the drum, and then it falls off dramatically as the wraps increase. So, go larger than you can barely live with, and you will be much happier.
Also, watch out for the wireless remote control winches. If you never need one, wireless is great. But, when I need one it means my front end is stuck under a couple feet of slop and the wireless system does not work anymore. It is bad enough to have to dig for the cable, but when I have to also use a wrench to wrap the winch cable by hand under the slop, it really sucks!
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 10-11-2009   #3 (permalink)
gcoultas1
So you are saying that when it is bad enough to need a wireless remote then it is too bad to work, so it’s kind of pointless. Whit the rating a 4000lb would probably be more suited for when I get stuck in the mud.
Old 10-11-2009   #4 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
I like my mile markers I have on both my trucks, and my quads.
And yes, always buy more winch than you think you will need.
On just my little old Honda foreman 450 quad, a 2000 pound winch was not enough when it was really stuck, and its just 600 pounds.
I now have 3500 pound winches on both my quads, and its a lot better.
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Where do i mount winch on trans mule 4010 need pics blairg Kawasaki ATV and Mule 7 05-14-2009 07:39 AM
Installing Winch on Mule 3000 stevegannon Kawasaki ATV and Mule 3 12-23-2008 12:38 PM
Winch advice for Diesel 3010 Trans Mule Green075 Kawasaki ATV and Mule 4 07-12-2008 01:51 PM
Mule 3010 Trans Winch Installation Problems jonesj65@hotmai Main Lobby 0 06-14-2008 09:05 PM
Mounting winch on mule? cdharris Kawasaki ATV and Mule 7 01-05-2006 09:34 AM
