Old 10-13-2009   #1 (permalink)
bnjracing13
Default Brute Force 750 Thick Milky Differential Oil HELP!!
I have a 2007 brute force 750 that i recently bought. Well i decided to go ahead and service it and went to drain the front differential; but only a thick milky sludge came out in clots! How do i clean all this mess out the right way?
Thanks
bnjracing13 is offline   Reply With Quote
Old 10-13-2009   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
basically you are goin to have to flush it out.
i have used diesel fuel with the diff oil and run it for 15 min and then drain it out.the diesel fuel will clean with out hurtin nothing.but only use a 1/4 cup per qt of oilor a3to 1 ration 3 part oil 1 part diesel.ounce. ounce you havedrain and refilled the diff with new oil.ride it for about 5-6 hrs and change it one more time while its hot,this will make sure all the milk shake color is gone.
hope this may help out -corey-
Old 10-13-2009   #3 (permalink)
wabco63
bruteforcevoyagerzx12
if it was me , I would use brake clean , then fill it with proper oil , ride it then change it when warm and repeat
wabco63 is offline   Reply With Quote
Old 10-14-2009   #4 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
I had milk in my Prairie 400's diff when I got back home from my mudding trip. The vent hose had slipped off at some point...
I left the drain plug out for two days, filled it to the top with kerosene, ran it up and down the driveway 4 times, drained and filled it with kerosene again, ran it four more times, and then refilled with 80-90 gearoil and limited slip additive. No more milky.
99prairie400 is offline   Reply With Quote
anyone have a brute force 750? 1badbrute Kawasaki ATV and Mule 21 10-02-2009 09:19 PM
HELP! Persistant Problems with Brute Force 750 DustinSwin Kawasaki ATV and Mule 5 07-26-2009 12:11 PM
in the mail - Vulcan 2000 Oil Level Check Procedure Spok Kawasaki Cruisers 22 11-05-2008 12:19 PM
Bike Oil vs Car Oil... Brett The Mechanics Corner 55 08-05-2008 10:24 PM
2005 Brute Force 750 4x4 for sale grandpawmoses Offroad Buy/Sell/Trade 0 12-04-2005 11:01 AM
