Getting a clutch burning smell after drives on the Mule 1000. I jacked it up last night and checked al the brakes and they are all spinning free. This Mule was sitting outside for a few years with out running. What would I need to check as far as the belt, could this be the problem? The warning buzzer is not hooked up and will hook it up when I get home. Where do I need to check for wear? Hopfully it is just the belt, so what is the easy way to change it? Thanks
Insect Impact Analyst
![]() Join Date: Mar 2008
Even though your brakes spin freely, it could still be a problem with the brakes. I have heard that if you get a lot of moisture in the fluid (and brake fluid attracts moisture) that they expand more when heated up and do not return to their normal position. Might be worth flushing and bleeding the brakes and see if that helps.
Bugs, it's what's for Dinner! 97 Honda ST1100 (Big Red) R.I.P. 97 Ninja 250 (Lil' Red) |
| Is shimming my clutch push rod an acceptable solution? | Neep | Vintage Motorcyle Info | 7 | 08-25-2008 05:20 PM |
| Vulcan Clutch Problem | KustomKruisers | Kawasaki Cruisers | 6 | 08-08-2008 06:13 PM |
| V2K Clutch problem update. | LordGT | Kawasaki Cruisers | 5 | 05-28-2007 01:10 AM |
| V2K Clutch Question. It's a goodie | LordGT | Kawasaki Cruisers | 6 | 05-22-2007 01:58 AM |
| Help: Clutch / Cable Fitting Loose | Neo | The Mechanics Corner | 1 | 09-27-2004 12:34 PM |
