Old 10-15-2009   #1 (permalink)
norscott
Default 2510 diesel alt belt schroud clearance to axle
Just bought a 2001 4x4 2510 deisel.
Overheating...fan never ran so, thought fan switch... easy... after fan switch r&r still didn't run fan went to look at thermostat... filled all waters and checked for circulation of water when running. None. Never dreamed the fan belt would be off. Actualy burned and broke, the shroud was missing bolts, broken, and had fallen down onto the waterpump fan an worn down the blades until friction caused belt to break. OK now the question... Since the shroud was broken in 2 pieces I could squeeze it down past the crank pully and the drive shaft. After I weld it back together, there is no way there is enought clearance to re install it past the axle - <3/4" and shroud is +1". Do I remove the drive shaft intermediate bearing or what??? Jack up the motor? what is the seceret? And... Do I need to get a new fan... seems kind of useless, it is intact just a little shorter because it rubbed - a lot.
norscott is offline   Reply With Quote
Service manual belt tension for 900?? Alf Kawasaki Cruisers 25 05-11-2009 08:08 AM
Bought a 2006 2000 Classic LT, Need Advice oolddog Kawasaki Cruisers 22 01-27-2007 10:31 AM
2510 4x4 belt nobuddy Kawasaki ATV and Mule 1 12-14-2006 11:34 AM
2510 Mule Axle Removal flaing Kawasaki ATV and Mule 6 08-31-2006 10:47 PM
2510 Diesel Mule Drive belt Replacement Koboss Kawasaki ATV and Mule 4 08-23-2006 03:04 PM
