Old 10-17-2009   #1 (permalink)
jgerrish81
Question HELP!! 98' kawasaki Prairie 400 4x4 issues starting....
Hoping someone will know what I need to do. My ATV only starts by pull starting. Battery charged have two of them one brand new, allows lights to come on, when starting it starts a clicking noise?? There is no spark from battery and cables? What should I check for, hoping its not the starter. I have been able to start very few times after its been running by pull start and I shut off then try??? anyone who could help me out??
jgerrish81 is offline   Reply With Quote
Old 4 Weeks Ago   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
have you check the connections at the soliniod yet and at the starter?
may just have a bad solniod nad or connections .give them a try -corey-
Old 4 Weeks Ago   #3 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
First, a few things to check...
Find a multi-meter. Check to make sure that your battery has 12V~ at the terminals.
The solenoid is located between the airbox and battery underneath the seat. It has two large wires (one coming directly from the battery) and two small wires connected to it. The large wire connected directly to the battery should have 12V~ all the time. The other large wire goes to the positive post on the starter. Trace each point of the large wire with the multimeter while someone is holding the starter button in the "start" position. You should be able to find 12V~ at every connection point (battery terminal, one side of the solenoid, the other side of the solenoid, positive post on the top of the starter) If you can find 12V~ at each connection point to the top of the starter, it points to a bad starter. If you cannot find 12V~ at every connection point, report back your findings.
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
Old 4 Weeks Ago   #4 (permalink)
jgerrish81
Default found problem
had 12v at starter motor banged lightly on the starter with small hammer fired right up 10-12 times starting to here starter drag think it needs a rebuild or a new one
thanks for all the help
Old 4 Weeks Ago   #5 (permalink)
99prairie400
Good detective work. Probably rebuild/purchase a used one off EBay to get you back up and running as inexpensive as possible.
99 Prairie 400 4x4
98 Bayou 400 4x4
2000 Kawasaki Prairie 400 Drive pully puller alternative? Nicos The Mechanics Corner 0 02-12-2009 05:15 PM
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Kawasaki Bayou 400 4x4 needs help!!!!!!!!!!!!!!!!! METHODMAN44266 Kawasaki ATV and Mule 2 01-27-2006 12:35 AM
97 prairie 400 4x4 98KLR650 Kawasaki ATV and Mule 0 07-28-2005 03:28 PM
Kaw Prairie 400 4x4 Igniter question!!! Cybercop106 The Mechanics Corner 1 05-14-2004 11:46 AM
