Old 4 Weeks Ago   #1 (permalink)
ivarraven
Default Mule Plow Problems
Hello,
So once again, another Alaskan extreme cold weather problem.
I have a Curtis oem large plow, and the actuator is just at its limit. It'll lift okay, but once snow weighs the plow down or the temperature is below -10, the clutch just slips on the linear actuator. Also, I'm going to buy a much faster and higher capacity actuator sometime soon to deal with the conditions. I'm trying to get a power angle on the plow, but the measurements are all odd, so I wouldn't get a full stroke if it will fit. Is there a Curtis hydraulic system out there that I can get that will fit correctly, or do I need to get the local U.S. Bearings and Drives dealer to get a custom made system of warner linear actuators. Once I get this to work, I'll post some pics of the whole system and send out the specs, so that any other oem plow owners can get a power angle/lift. Any ideas?
Thanks
ivarraven is offline   Reply With Quote
Mule 610 problems magoy Kawasaki ATV and Mule 1 12-15-2008 08:38 PM
'05 3010 Gas Mule Power Problems CCOBB Kawasaki ATV and Mule 14 11-12-2008 04:31 PM
Time to buy a Mule!! TWmachine Kawasaki ATV and Mule 11 06-23-2008 08:49 PM
Mule 2500 Solution to Rough Run sonny Kawasaki ATV and Mule 1 12-12-2005 11:59 AM
idle/carb problems babee_huey Main Lobby 3 08-12-2004 01:34 AM
