Old 4 Weeks Ago   #1 (permalink)
North Woods
Default How??? replace starter chain '86 300 Bayou?
First off, "Hello" to everyone here on the forum. As you have seen before, the first post is a tech. question, albiet an easy one, I hope.
My 1986 KLF300 Bayou 2wd has a starter issue. Starter seems to have plenty of snap but either kicks out harshly or possibly the chain is slipping. I pulled the big cover off to expose the chain and it is hanging low enough that it rubs on the cover a little bit.
So, the question, can I get the chain off by simply removing the phillips-head screw that holds the flat retainer thingy or do I pull the starter from the other side?
BTW, my Dad bought this Kawi new in 1986 with the money he was going to save by quitting smoking. He has since gotten a newer one but I kept the old one. I love it and want to keep it going.
Also, about a tablespoon of oil came out when I took the cover off, what should I put back in and how much?
Thanks in advance for the help.
North Woods is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
North Woods
got the chain replaced, had to drop the exhaust to make room to get the starter out. Put on a new chain but have not found a new small gear yet. Seems to be working fine enough though.
Old 2 Weeks Ago   #3 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
What type of small gear are you talking about? The intermediate gear?
Good to hear you got'er back together
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
1994 Bayou 220 Starter Issues SWLA Bayou Ride The Mechanics Corner 1 12-28-2008 09:36 AM
kawasaki bayou 220 starter problems... ChadD The Mechanics Corner 8 10-21-2008 08:07 PM
86-89 Bayou 300 slafreni Kawasaki ATV and Mule 1 08-27-2008 11:40 AM
Bayou 300 1997 Starter Problems HKDJ The Mechanics Corner 0 10-24-2006 11:20 AM
Bayou 220 Starter Problems... mrlong27574bayou220 Kawasaki ATV and Mule 3 12-05-2005 02:21 PM
