Old 3 Weeks Ago   #1 (permalink)
eaker02
Made It To Second Gear
eaker02's Avatar
Default KEBS/KAP 400 Prairie
Hi,
I'm on the Cruiser forum with a 2007 900 Vulcan Custom.
My question is, a friend is trying to get me to buy a 4 wheeler he has. I gradually looked at it. It read KEBS or KAPS 400 prairie and its a automatic and 4 wheel drive, camouflage seat, etc.
I thought this thing might have been Chinese or something, but when I was google didn't find much other than it might be a Kawasaki, but didn't see kawasaki anywhere on it.
does anyone have any information on this ATV and what is KEBS/KAPS? He's had work done to it, new brakes, etc. but will need a new battery, fuel cutoff valve, etc.
ot even sure what year it is, can't find to much info and not sure what to search on in the archives if this is a Kaw.
thanks
ron
Ron
2007 900 Custom
1974 BMW 2002Tii
eaker02 is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
If it says KAPS on the side it's a '97-'98 Prairie. KAPS stands for "Kawasaki Automatic Power System". The '99--01 said "automatic 400" on it. if it says KEBS on it it could be a 650 twin or a 360 because it stands for "Kawasaki Electronic Braking System"
There are a few issues to look out for. The engines are strong as long as they are taken care of. If they weren't taken care of, they are expensive to repair. The clutch/drive train is a weak link. They wear out pretty bad and are fairly expensive to replace/rebuild. The rear rims are 10" so difficult to find replacement tires for anything in an aggressive tread. The front springs sag out pretty bad even without any extra weight like a plow or anything so if you plan on carrying anything up there you can opt for the Kaw heavy duty springs but they are expensive (about $170 per side)
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
Old 3 Weeks Ago   #3 (permalink)
eaker02
eaker02's Avatar
Thanks, so it actually could had said KEBS? Couldn't find much info that compared to KAPS, so thought I made a mistake. I know it did say automatic on it and did not have a rack but some type of roll on the front. As to the size I thought it said 400 or 450, but from what I read don't see a 450.
I have to take another look at it.
thanks for the advice, only reason for buying one is so I could put a plow, aerator, etc on it.
Also the pull start does not work, the rope pulls out but doesn't turn anything over.
thanks
ron
Ron
2007 900 Custom
1974 BMW 2002Tii
Old 3 Weeks Ago   #4 (permalink)
99prairie400
I'm sorry, I misquoted. The later Kawasaki belt drive quads use KEBC or "Kawasaki Engine Brake Control"
They apply pressure to the outside of the primary clutch during downhill off-throttle rides putting the "transmission" in "low gear" to slow the quad down.
If it said KEBC on the side it's a later model, and not a 400
If it said KAPS on the side, it's a '97-'98 KVF400 (Prairie 400) The '99-'01 just said automatic 400 on the belt cover.
99 Prairie 400 4x4
98 Bayou 400 4x4
360/650 Prairie Belt Actuator Interchangeable? lucy1030k Kawasaki ATV and Mule 1 03-26-2009 04:17 PM
Prairie 360 Skid Plate needed. Patsplace Kawasaki ATV and Mule 1 01-26-2009 05:43 PM
New Prairie owner with a question on size... QUINNY69 Kawasaki ATV and Mule 1 11-23-2008 10:01 PM
Kawasaki prairie 300 1999 mag wheel help reisset Kawasaki ATV and Mule 0 11-06-2008 10:09 AM
Prairie 650 Valve adjustment TrailBuster Kawasaki ATV and Mule 2 07-28-2005 02:41 PM
