Old 3 Weeks Ago   #1 (permalink)
#34 KX 250
The original #34
#34 KX 250's Avatar
Default 2008 BF 750 4x4i question
im a newbie when it comes to quads but i have 10+ years experience on bikes. Either way i have a question, why does my brute force keep dying when i go through water thats not even near my foot pegs in depth? i have seen many non-snorkeled quads going through seat deep water.
is the intake on my utility quad by my front diff or what?
C.Norberg #34 Monster Energy Kawasaki KX250
#34 KX 250 is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
Alright, Water-proofing.101
The limiting factor on any quad is only the lowest sealed thing that keeps the engine running. For a stock quad it's usually the ignition system. For a modified mud racer it's usually however tall the snorkel reaches above the rack. (search HB boys busco for an idea of how deep a quad can continue to run under water, the engine was still running at the beginning of the video, the driver just couldn't hit the throttle anymore so they had to winch it back out)
You're probably experiencing ignition system shorts from splashing water. The coil and wire end is usually sealed together but the spark plug boot is relatively exposed. It has a lot of voltage running down that wire and even a little bit of moisture will short the plug out. The way to water proof your ignition is to remove the spark plug boot, shoot a good healthy squeeze of di-electric grease into the boot, and re-install. The use of a small tie-strap to help hold the boot down around the spark plug a little better is personal preference and application specific. I have run my Bayou 400 across a pond with 8" of water over the handlebars without a tie-strap on the spark plug boot but if you have room for it, it's not a bad idea.
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
SWBF
SWBF's Avatar
Your air-intake is in front of the air box, right above the header pipe, steam could be the problem. All it takes is either water or steam vapors to get sucked in and you will stall.
08 BF750 - Sold
07C/A 800 but didn't like it, sold it.
Soon a new '09BF750 lime green or '10BF750
SWBF is offline   Reply With Quote
Old 1 Week Ago   #4 (permalink)
#34 KX 250
The original #34
#34 KX 250's Avatar
I found a healthy amount of water in my airbox and my air filter was pretty damp.
Old 1 Week Ago   #5 (permalink)
99prairie400
I'd say it wasn't steam and it wasn't your spark plug shorting out. You may want to think about snorkeling the beast. I'd hate to ruin an expensive monster like that by sucking up a little water.
99 Prairie 400 4x4
98 Bayou 400 4x4
1972 H2 750 Kawasaki question zen4me Vintage Motorcyle Info 59 2 Days Ago 08:27 PM
1982 750 Spectre Question? Panterawhiskey Vintage Motorcyle Info 1 10-06-2009 12:26 AM
