Old 3 Weeks Ago   #1 (permalink)
tim1
Default Tire clarification for a 3010 mule 4x4
I know you fellas will know this from experience, so here goes. I use my mule in low range 4x4 exclusive and would like the most ground clearance as possible. I do not want any kind of lift kit or mods that way. I can buy a 25x11x10 mud lite to go on the stock rims. Will they bottom out or rub? It is just me and my dog on the trail and just me with fire wood in box for house. The tires are 6 ply with 3/4" lugs. I can also get the same tire in 24x11x10. Stock dunlops are 23x11x10. I did a search and really did not get a good answer. Thanks Tim
tim1 is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
RCW
Way Too Much Free Time
Sorry to say, if you intend to haul firewood, the answer is the larger 25 inch tires will rub. The 24 inchers will work if you are not bouncing over rough roads at speed.
I am not keen on larger tires or even the lift kits. I just hauled four elk out on mine all at once with stock tires in 22 inches of snow without any problem at all. I hauled the camp in through mud and snow without any problem and with six guys loaded up too.
I also do not break the rather expensive steering boxes from overstressing due to excessive leverage from larger tires. But, I understand I have two at the shop with just that problem from beating around with larger tires on rough ground, waiting for me when I get back home from my hunting. Not good for them, but it will pay for my hunting trip, so it is good for me!
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 3 Weeks Ago   #3 (permalink)
tim1
Thanks rcw, I will stick with the 23" and the 4 ply tires. With the diff lock and limited slip in the front, I should be alright. Really do not want to break things! Tim
Old 3 Weeks Ago   #4 (permalink)
MICKEYTKD
Made It To Second Gear
if you do decide to go a different way avoid the mudlites and try the swamplites instead. I had the mudlites and they gooped up quickly. not a problem with the swamp lites
MICKEYTKD is offline   Reply With Quote
A little follow up on my blistered Metzler Richard Kerr Kawasaki Cruisers 6 09-09-2009 10:27 PM
How I Changed My OWN Tires jeffs99vulcan Kawasaki Cruisers 51 08-30-2009 05:08 PM
Kawasaki Mule 3010 different Kawasaki ATV and Mule 3 01-25-2009 05:00 AM
Mule 3010 (2005) Need Parts Smokinstang70 Kawasaki ATV and Mule 5 12-18-2007 12:56 PM
Mule 3010 4x4 Questions john_bud Kawasaki ATV and Mule 10 12-11-2007 08:11 AM
