This thread goes along with the "Starter Clutch" thread..
I'm looking at the flywheel and starter drive gear behind it that fits into the sprag clutch.. With my fingers I can spin the gear in both directions and it's flopping around loose behind the flywheel... Is the flywheel puller needed here common to other engines or is the one I need unique to THIS engine. The center bolt measures 10mm and the external threads on the flywheel hub measure 29mm. The factory puller is a $150 part for both pieces.. It's not like I'm six blocks away from a Kawasaki dealer..I'm 250 miles south of the border in Mexico..As a last resort, if I can remove the flywheel, I can remove the damaged clutch and gear and button it up until I can get the parts I need, using the recoil starter to start the machine..Has anyone else had to deal with this?? |
Success! Using a standard issue 2-jaw puller, the flywheel popped off without any drama..The starter clutch it turns out is okay! What happened is the 3 short Allan head bolts that hold the starter clutch to the flywheel had sheared off, allowing the clutch and gear to flop around behind the flywheel. A trip into town and the nut and bolt store and I'm back in business! Whew!
| 94 220 Bayou Clutch Removal | tjb5304 | Kawasaki ATV and Mule | 4 | 01-29-2009 06:25 AM |
| Bayou 220 bearing removal trouble | tsankou1 | Kawasaki ATV and Mule | 1 | 08-19-2008 10:49 PM |
| Bayou 220 Bearing removal | tsankou1 | The Mechanics Corner | 1 | 08-19-2008 10:38 PM |
| '88 Bayou 220 flywheel removal help | rollcage | Kawasaki ATV and Mule | 2 | 06-27-2008 09:19 AM |
| Bayou 220 Seat Removal | HotDish | Kawasaki ATV and Mule | 1 | 10-20-2006 05:28 PM |
