i have a kawasaki mule 1000 older model and just rebuilt carbs and have checked them numerous time float are set right, however when i push the accelerator it is bogging down as if it is not getting power??? the valve in the carb is fluttering when accelerator is applied do I need to change carb????
Way Too Much Free Time
There are two things that cause carburetor air valve flutter, perforated diaphragm, or valves out of adjustment.
Do not waste your money on new carburetors unless the carb body itself is shot. Pick up the diaphragms if the problem remains after you adjust the valves. You can see how they are build on kawasaki.com, just follow the owner info link to the parts diagrams.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#3 (permalink) | |
