Old 1 Week Ago   #1 (permalink)
Bushpilot1951
Default Prairie 400 Wiring Diagram
Hi. New poster. I bought a wrecked 1997 Prairie 400. Ii had everything on the left side missing or broken. I specifically need the wiring schematic for the electrical controls. I found a newer model on ebay, with the same number and color wires. 3 are matched up and 3 are different. Anyone help?
Bushpilot1951 is offline   Reply With Quote
Old 1 Week Ago   #2 (permalink)
99prairie400
Top Gear Full Throttle
99prairie400's Avatar
I have the factory service manual for the 97-98 Prairie 400 and the supplement for the '99 Prairie 400. Which part of the wiring do you need? Stator/ igniter wiring only? That's all I can think is on the left side.
99 Prairie 400 4x4
98 Bayou 400 4x4
http://www.myspace.com/sicivicdude
99prairie400 is offline   Reply With Quote
Old 1 Week Ago   #3 (permalink)
Bushpilot1951
Default Wiring Prairie 400
Hey, I wired the electrical switch on the handle bar and everything works fine. I only have one question, what is the over-ride switch for? I would like to have the schematics for all the front end wiring, especially the over-ride switch. The wires coming out of the over-ride are brown (hot?) and yellow. I can only find a blue and brown wire near the main connector from the switch in the left wheel well. Thanks for replying. Gotta go see if I can get it stuck today!!
Old 1 Week Ago   #4 (permalink)
99prairie400
For your safety, reverse has a rev-limiter. If you are stuck however, you need full speed in reverse. Hold the over-ride button and the quad will spin the tires 25MPH backwards.
99 Prairie 400 4x4
98 Bayou 400 4x4
Kawasaki Prairie 400 4x4 Service Manual huntinglonewolf Kawasaki ATV and Mule 0 07-13-2009 03:15 PM
My wiring diagram is throwing me curveballs. MrGiggles Kawasaki ATV and Mule 33 01-21-2009 09:02 PM
Bayou 400 Wiring Diagram............ KLT Man Kawasaki ATV and Mule 4 11-20-2007 07:15 PM
kawaski KZ550LTD wiring diagram needed lildipper62 Vintage Motorcyle Info 5 05-23-2006 12:33 PM
Wiring Diagram or Manual 400 LTD PeterL Kawasaki Streetbikes/Sportbikes 2 12-24-2005 12:47 PM
