new owner, I got it home drove it and parked it, and now it won't start. I check all fluid levels before operating, only ran it for around 1 hr, it was in the 50's as it idled I heard the fan come on.........thought it was normal. I have been through all filters dumped and cleaned fuel tank, new plugs verified spark, verified fuel pump. then I noticed reervoir was empty, radiator was down 2 oz. mouse had eaten through hose to reservoir. will replace hose today. I also put a new stater on it and had back end jacked up for access for several days. Did this drain all fluid to the radaiator and leave air gap in system? Is their a fail safe built in if there is no fluid it won't start? I did check presure in cylinders when changing plugs, it was only 60LBS per cyinder, way to low.......did I psssibly blow head gaskets? is there any way of checking if I did, other than low compression reading? any and all comments would be appreciated. Help please
LinkBack URL
About LinkBacks
