96 Kawasaki Bayou 220 Electric Start
+ Reply to Thread
Results 1 to 3 of 3
Thread: 96 Kawasaki Bayou 220 Electric Start
  1. #1
    Join Date
    Sep 2009
    Posts
    6
    Default 96 Kawasaki Bayou 220 Electric Start
    Hello
    I just picked up a 96 Kawasaki Bayou 220. It starts no problem with the pull start, but wanted the option of electric start. I pulled up the seat and orders some parts. I got a new relay, a used starter selinoid, new battery and new battery leads. well after charging the battery and hooking up the wires put a new 20amp fuse in. I go to push the starter button and nothing, the lights don't even turn on. someone told me to test the start selinoid (since it was used). So I connected the pos wire of the meter to the pos pole on the battery and I touched the neg on the selinoid I got no reading on the 2 connectors (hot to relay) closer to the noid and then I got 12.5v reading on the 2 (hot to switch)outer connections. Did I test it right? Do I have a bad selinoid? Am I missing something? Would this stop the lights from working? Please help.
    Thanks
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    Default Re: 96 Kawasaki Bayou 220 Electric Start
    Sort of sounds like you are trying this without a service manual. Not a good idea, as you can fry the igniter and pretty much exceed the value of the ATV by the time you complete repairs.
    Go to Kawasaki.com and follow the Owner Info to the parts diagrams. Take a look at the Chassis Electrical Equipment slide and the Starter Motor slide. There are two solenoids, both have to be functional as does the key switch.
    If the solenoid in the Starter Motor slide is bad you will blow the fuse for your main power supply. If the solenoid on the Chassis Electrical Equipment slide is bad you will get no power anywhere, just like blowing a fuse.
    If toys will get me in the door when it is time to go, I have it made!
  4. #3
    Join Date
    Mar 2010
    Posts
    15
    you should clean all the ground,battery,solenoid contacts with a wire brush. I had the same problem
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 1992 kawasaki bayou 220 - S/N location help.
    By Raina in forum Kawasaki ATV and Mule
    Last Post: 11-25-2009, 09:21 PM
  2. HELP~ 2002 kawasaki bayou 220
    By caseyharris12 in forum Main Lobby
    Last Post: 09-06-2009, 12:00 AM
  3. 96 Bayou 220 Electric Start issue
    By apso1857 in forum Kawasaki ATV and Mule
    Last Post: 01-08-2009, 07:15 AM
  4. 2001 kawasaki bayou 220
    By dktoth in forum Kawasaki ATV and Mule
    Last Post: 03-06-2008, 07:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
