Kawasakie Mule 4010 diesel 4x4
+ Reply to Thread
Results 1 to 11 of 11
Thread: Kawasakie Mule 4010 diesel 4x4
  1. #1
    Join Date
    Jan 2011
    Posts
    3
    Default Kawasakie Mule 4010 diesel 4x4
    I am working on a mule that is a diesel enigne. The people who had it before put gas in the tank and there was water as well. It sat like this for month. I have drained the tank and replaced the fuel filter. I'm trying to find out how to time this engine. I noticed the big gear in the middle, but i dont see any timing marks. I'm trying to pull the fuel injection pump off to clean it out. Also does anyone have a diagram of how the injection pump is put together?
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Jan 2011
    Posts
    3
    Default Re: Kawasakie Mule 4010 diesel 4x4
    Just so that you know i am not able to go down and purchase anything and etc. I am deployed in Afghanistan right now. My main job here is a generator mechanic, but to get around I was given this Mule. I just need to fix it. Any and all help with this will be great.
  4. #3
    Join Date
    Jan 2011
    Posts
    5
    I am speaking on behalf of the B&S 953, but I believe it to be pretty much the same. First thing would be to mark a line between the IP and the gear case. This will allow you to set the pump back to the original place it was with regards to the cover. The IP drive gear is keyed. Next, between the crank, idler, cam, and IP drive gear, there should be letters. There will be an A, an AA, a B, a BB, and finally a C and a CC. I believe this will get you going.
    Also, rereading your comment, I see that you are looking at the Harmonic drive pulley. That will have to be taken off with a puller then the outer half of the gear case can come off to access the bolt on the IP drive gear.
  5. #4
    Join Date
    Jan 2011
    Posts
    5
    Just for future reference, the marks that you see on the pulley are for the gas version of this engine to set the distributor.
    specifications
  6. #5
    Turtle Wax Taster BTK Intermediate
    Join Date
    May 2006
    Location
    Moses Lake, WA Summer, San Tan Valley, AZ winter
    Posts
    180
    Can you use the transfer pump to purge the system w/o doing the R&R on the pump? This would include the lines to the injectors. Then run it on clean fuel with a additive package if you can get it there to complete the gasoline and water removal? MAybe even a jury rigged system set up like in IV drip hung up high if it doesn't have a hand purge pump on it. Max
    Max from Thumper Acres, home of the single cylinder 4 stroke motorcycle.
  7. #6
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    The advice regarding the B&S engine is spot on. They are the same identical engine with only difference being the crankshaft from the turbocharged version is used in the Mule.
    If you are a military generator mechanic you fully understand the dangers of opening the pressurized fuel lines on the injection pump when purging. And, you already know how to prime one. So, that being the case, I would not remove the pump, but would use diesel and purge the thing by loosening the output lines at the fuel distributor, and let the starter spin the pump and purge the gasoline.
    Keep a water hose handy so you can spray the gasoline vapors with water as they blow in the air. They will be very explosive. A good CO2 extinguisher will be handy to have on hand just in case.
    If the fuel mix evacuates from the pump, then you will not need to rebuild the pump. If it does not, these pumps are really not worth the cost of the parts to do a field fix. They are a distributor style and are best just replaced with one that has been benched and tested after rebuild. 99.9% of the field rebuilds on these pumps fail! 100% of the swaps for a rebuilt bench tested pump are successful.
    If you have water in the system, the damage will be in the injectors and unlikely in the pump. You can disassemble the injectors and clean them, but the pattern will be garbage and power will be next to nothing. If the water never got past the filter, do not worry about it.
    If toys will get me in the door when it is time to go, I have it made!
  8. #7
    Join Date
    Jan 2011
    Posts
    3
    to RCW.. well they people that put gas in it actually drove it a few feet before it died on them. so the water and fuel were in the injection pump. I let the fuel lines air out and then soaked them in diesel. i did the same with the injectors. Being a generator mechanic i see this issue a lot. I get generators in that people but gas in instead of fuel. Most often I can drain the tank and clean it. Then after putting clean fuel in, pop off the fuel lines and purge it until i get good clean fuel. Then hook the lines back up to the pump, disconnect the lines coming out of the injection and let it crank over until I get good clean fuel coming out of the injection pump. Then reconnect the fuel lines and start it up. I tried this exact thing but it failed. Another mechanic tried working on it before I was told I had to work on it. They took the back plate off the pump so now i am assuming that the injection pump is just waisted. To TheMitch.. thanks for that advice. Like RCW said and from what i see on the mule i have they sound the same. That is going to come in handy since it sounds like i'm going to have pull that injection pump off and try to find another one!
  9. #8
    RCW
    RCW is offline
    Join Date
    Nov 2007
    Location
    Posts
    3,781
    That is a shame the pump was opened up. Usually a small amount of water in gasoline will not cause a problem unless air is allowed in the pump. Once air is introduced you get phase separation, acid formation, and immediate rust that ruins the pump.
  10. #9
    Join Date
    Jan 2011
    Posts
    7
    Kawasaki Mule 4010 diesel 4x4 is hard to access the location in safety & comfort. Mule 4010 is diesel's liquid cooled also 953cc 3-cylinder engine.
  11. #10
    Join Date
    Jan 2011
    Posts
    1
    Quote Originally Posted by TheMitch View Post
    Thanks for the advice, I don;t have access to a repair manual, but i was wondering if you could tell me the gap spacing for this vehicle. we rebuilt a ceased engine, it runs... but it sounds like we have too much of a gap now
  12. #11
    Join Date
    Jan 2011
    Posts
    5
    With a cold engine, both intake and exhaust should be set to .20 mm or .008 inches.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Issues after replacing drivebelt Mule 4010 trans diesel 2009
    By scooper12 in forum Kawasaki ATV and Mule
    Last Post: 01-09-2011, 09:41 PM
  2. 2009 4010 Diesel Mule Slow
    By Kuhns07 in forum Kawasaki ATV and Mule
    Last Post: 10-03-2010, 03:26 PM
  3. Mule 4010 Diesel Rear Drive Shaft Guards???
    By 604 in forum Kawasaki ATV and Mule
    Last Post: 09-21-2009, 07:27 PM
  4. 4010 Diesel oil, what to use???
    Last Post: 09-16-2009, 02:33 PM
  5. Approximate MPG for Mule 4010 Diesel
    By JStrong in forum Kawasaki ATV and Mule
    Last Post: 01-29-2009, 05:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
