I am 100% sure the carb cannot get any cleaner.
I knew I should have looked at the flywheel key. I also need to figure out the knocking noise this thing makes. I searched some old bayou posts and read that some people had a worn primary clutch cause knocking sounds. Do you think I should look into that? I haven't found anything on it yet that would cause the sounds it is making.
LinkBack URL
About LinkBacks
