The other day, I accidentally ran out of gas for the first time on my mule. It sputtered and tried to start, then died. I checked the fuel level, and it showed Empty. I added 5 gallons of fuel, and thought nothing of it, until today when I went out to use it. I cranked it, pulled the choke as usual,, and got nothing, no start. The engine cranks just like usual, just no start.
I pulled the air hose from the air cleaner off the black box and and could smell raw gas, so I think I have it flooded now. I tried a small shop of either, and it did not seem to notice that either.. I am working alone so its difficult to check for spark. The unit has just 310 hours on it, and the previous owner replaced the igniter just prior to selling it to me. I have the manual, but it is spotty at best in the troubleshooting area.
If you run out of gas do you have to reset something to get it running again?
Just back from mule, checked ALL the fuses,, all are ok.
I have noticed that lately after the mule is warmed up, when I stop it tends to idle down and quit, bt has been easy to restart..
LinkBack URL
About LinkBacks
