no 2wd
+ Reply to Thread
Results 1 to 4 of 4
Thread: no 2wd
  1. #1
    Join Date
    Nov 2010
    Posts
    10
    Default no 2wd
    my mule will not go into 2wd and the rear axle doesn't turn in 2wd'what to check please,thanks
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    Default Re: no 2wd
    Which model and year?
    Although if it is not turning the rear axle when in two wheel drive, but works in four wheel drive, I would tend to believe the rear differential section of the transaxle is the problem.
    If toys will get me in the door when it is time to go, I have it made!
  4. #3
    Join Date
    Nov 2010
    Posts
    10
    Default Re: no 2wd
    Sorry,I think it't a 2004,It is a 3010 and should have said it doesn't have rear wheel drive when in 4wd or 2wd,the rear axle doesn't move,Thanks
  5. #4
    RCW
    RCW is offline
    Join Date
    Nov 2007
    Location
    Posts
    3,781
    Default Re: no 2wd
    I would jack it up so it was secure and all four wheels were off the ground. Then remove the drive belt so there is no drag on the transmission. Put it in two wheel drive.
    Then I would find a helper and turn both rear tires in the same direction. Then lock the differential lock and try it again. Then try turning once wheel backwards and the other forward with the differential locked. Keep the engine off.
    If you get a click when turning one wheel forward and the other backwards it will be likely you have a broken axle. If you get grinding and gear rake noise it will be time to tear down the transmission section and repair the differential.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2WD selector?
    By NEPAKawi in forum Kawasaki ATV and Mule
    Last Post: 08-28-2008, 04:52 PM
  2. Flashing 2wd/4wd on 05 Brute Force 750
    By Roofgunner in forum Kawasaki ATV and Mule
    Last Post: 07-26-2008, 09:18 PM
  3. Prairie 400 2wd steering
    By rrocke17 in forum Kawasaki ATV and Mule
    Last Post: 01-03-2007, 12:42 PM
  4. 1994 bayou 220a (2wd) i need your help......
    By QKENUF4U in forum The Mechanics Corner
    Last Post: 05-05-2006, 07:00 PM
  5. Prairie 360 2wd 10 hr service
    By JakeSpoon in forum Kawasaki ATV and Mule
    Last Post: 08-19-2005, 12:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
