Old 03-13-2006   #1 (permalink)
jhall
Default Bayou 220 carb adjust help needed
Can anyone please help. I have 92 Kawa Bayou 220, starts fairly easy, idle is erratic. when I rev it, RPM's linger, doesn't drop back down to idle speed rapidly like it should. As RPM's gradually drop it will pop and backfire through exhaust and/or carb. Blows no smoke. I have rebuilt carb to get rid of same problem. I have a feeling this is something simple, probably an adjustment of somekind. Thanks in advance for the help.
jhall is offline   Reply With Quote
Old 03-18-2006   #2 (permalink)
gbpacker51
I'd check the slider in the carb again, sounds like it's loose or not adjusted right. Also check the adjustment throttle cables, I had mine too tight and the idle speed would change as the handlebars were moved.
gbpacker51 is offline   Reply With Quote
Old 03-19-2006   #3 (permalink)
jhall
Thanks- There was a problem with the cable being too tight, (handle bars turn and speed would increase), fixed that. what are you referring to when you say "slider"? the big needle that is in the middle of the carb connected to the cable? The book calls for the needle clip on that to be at "2", but it doesn't tell me to count slots starting at the bottom or starting from the top, so I may have it set at 2 or it may be set at 4. Thanks
Old 03-19-2006   #4 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
always set the clip on needle from top to bottom (#1 on top and then down from there)
good find on the cable being to tight. from the description i would have thought of it being to lean.
QKENUF4U is offline   Reply With Quote
Bayou 220 Problem 36racin The Mechanics Corner 5 07-11-2009 05:12 AM
Bayou 220 - Help with Hoses TAQuickness Kawasaki ATV and Mule 6 01-16-2007 11:12 AM
KLF 220 Bayou Shifting problem KLF@@) Kawasaki ATV and Mule 1 09-10-2006 08:22 PM
Bayou 220 Question 36racin Kawasaki ATV and Mule 2 02-10-2006 06:54 PM
Bayou 220 Valves?????please help me captainmike Kawasaki ATV and Mule 1 11-17-2005 06:45 PM
