Old 07-07-2006   #1 (permalink)
mille989
Smile 1994 Mule 2500
I have a 1994 Mule 2500 and just recently had a issue with the engine overheating. There is sufficient coolant, but the fan does not come on. I want to test the fan and the fan switch, but I am unsure how best to get at the fan to do this. I use the Mule daily and can't afford to have it out of commission for very long at all. What is the easiest and quickest way to get to the fan and the fan switch? Do I have to remove the entire plastic cover over the nose? Is there an easier way to get access?
Thank you,
Nate
mille989 is offline   Reply With Quote
94 Kawasaki Mule 2500 idles a high rpm--HELP!! mule2500 Kawasaki ATV and Mule 1 05-25-2006 01:49 AM
Mule 2500 Solution to Rough Run sonny Kawasaki ATV and Mule 1 12-12-2005 11:59 AM
2500 Mule Coolant in Oil Texas Mule Kawasaki ATV and Mule 6 12-07-2005 04:54 PM
Mule 2500 wont idle bpollock80 Kawasaki ATV and Mule 0 10-17-2004 07:13 PM
what non oem oil filters will fit a mule 2500 markct Kawasaki ATV and Mule 1 09-21-2004 02:01 PM
