Old 07-16-2006   #1 (permalink)
ericchat
Default Bayou 300 weak spark
Does anyone know how to tell what year a Bayou 300 is? I just bought it and don't know what year it is. Also when I try to start it. it has a strong spark for an instant and then weak spark as it turns over. It won't start. It just occasionally pops like it's trying to start. using a shot of ether in the carb is no help.
ericchat is offline   Reply With Quote
Old 07-16-2006   #2 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
it will be the 10 digit in the VIN, which is stamped into the left hand frame under and infront of the left footrest, if it is a number such as a 1 i.e. as far as a weak spark, chect the connection of the 12 wires at the coil or you might have a sparkbox becoming weak
VIN Code Year Information
The Vehicle Identification Number (VIN) is stamped into the frame's head tube, which is located behind the headlight / front numberplate. The VIN code is 17 digits long. The tenth digit indicates the year model. To help prevent confusion, a few letters are not used. For example, is that the letter "I" or the number "1"? Below is a list of letters and numbers and the matching year:
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
9 = 2009
The list then repeats with A = 2010 and so on.
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
91 bayou 300 4x4 rear diff problems ty95daniel The Mechanics Corner 2 07-11-2008 05:19 AM
1992 Bayou 300 4x4 wont start skygunbro Kawasaki ATV and Mule 2 10-02-2007 11:18 PM
88 bayou weak or no spark allenbrand The Mechanics Corner 3 05-31-2006 10:03 PM
1992 Bayou 300 4x4 wont start skygunbro Kawasaki ATV and Mule 9 05-21-2006 11:19 PM
96 Bayou 300 won't start scottjima Kawasaki ATV and Mule 2 01-29-2006 09:58 AM
