Old 09-08-2006   #1 (permalink)
usry28
Question 2002 Praire 650 boggs
I have a 2002 Prairie 650 that boggs down when trying to accelerate. I just added gas to the tank from a local conv. store. It ran fine for 5 or 6 minutes and then my problem started. If you give it full throttle it will completely die. anyone know what the issue might be with my ATV?
usry28 is offline   Reply With Quote
Old 09-10-2006   #2 (permalink)
mitch4x4
check your vent hose from your gas cap sometimes they pinch and they make the machine run like crap or makes them die, also if it keeps doing it check your carb a piece of dirt might be stuck in there or something.
mitch4x4 is offline   Reply With Quote
Old 10-24-2006   #3 (permalink)
usry28
Found the Problem Finally
My problem ended up being dirtdobbers had almost completely stopped up the air supply tube to the air box. It was not getting enough air. The air supply opening on my 650 is located right behind the removeable cover on front of the steering column housing.
2002 KX 250 suspension question Thebadclam Kawasaki Motocross and Offroad 4 11-13-2008 10:59 PM
kawasaki 650 praire 4x4 oil pump problem mike72 Kawasaki ATV and Mule 1 10-25-2007 11:50 PM
2002 Prairie 650 boggs down usry28 Main Lobby 0 09-08-2006 08:04 PM
KAWASAKI 650 REAPERNINK666 Kawasaki Streetbikes/Sportbikes 4 05-24-2006 07:52 AM
Do the KLR 650 RADIATOR and PUMP Guard really work?? Turbo Boss Kawasaki Motocross and Offroad 1 12-24-2005 06:41 PM
