Bayou Starter Clutch Problems: whining
+ Reply to Thread
Results 1 to 3 of 3
Thread: Bayou Starter Clutch Problems: whining
  1. #1
    Join Date
    Oct 2006
    Posts
    1
    Default Bayou Starter Clutch Problems: whining
    I have a working 1995 bayou 220 - It starts fine with a pull start. I recently opened up the case to view the starter clutch, and noticed it sitting sideways in the case, not making contact with the pinion gear which is attached to the starter motor. The result is that when I hit the starter button, it whines- but does not engage that starter clutch, and thus not engaging the flywheel.
    Any suggestions?
    It seems a bit sloppy when I push it in its home. Will a new starter gear (Part 39076) also known as Limiter, Starter, IDLE - solve this problem?
    Thanks
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Apr 2007
    Posts
    1
    I'm having the exact same problem, did you ever get the problem solved or figure out what was wrong?
  4. #3
    Spend most time under it BTK Beginner
    Join Date
    Apr 2007
    Posts
    68
    Sounds like either the one way bearing has colapsed or the casings are flogged out and it's slopping around in there
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. kawasaki bayou 220 starter problems...
    By ChadD in forum The Mechanics Corner
    Last Post: 10-18-2012, 09:18 PM
  2. bayou clutch problems
    By bayouboy in forum The Mechanics Corner
    Last Post: 04-18-2009, 09:05 PM
  3. 81 kz-1100 starter problems
    By ggenovez in forum The Mechanics Corner
    Last Post: 02-15-2006, 05:47 PM
  4. Bayou 220 Starter Problems...
    By mrlong27574bayou220 in forum Kawasaki ATV and Mule
    Last Post: 12-05-2005, 01:21 PM
  5. need help with Bayou starter problem
    By gbpacker51 in forum Kawasaki ATV and Mule
    Last Post: 01-04-2005, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
